AROS One 64Bit v1.2 Realizzato
Messaggioda AMIGASYSTEM » mer ott 15, 2025 1:30 pm
All Download (Image ISO, Image USB, Update AROS One 64Bit 1.1-To-1.2):
AROS ABIv11 Core changes:
Functionalities:
C library extended with several wide char functions (Deremon)
SSE2/SS3/AVX accelerated pixel conversion routines (Kalamatee)
Updated several network drivers to work on 64-bit (Neil)
tiff.library has been ported and tiff.datatype implemented (Kalamatee)
Initial work on new partitioning tool (Kalamatee)
Added regular and SSE-accelerated pixel processing routines (Kalamatee)
font.datatype has been ported (Kalamatee)
zstd.library and lzma.library are not available (Kalamatee)
It is now possible to define Zune frames as rounded (Bo Stale Kopperud)
Updates:
Multiview (Russell Shaw, Mazze)
Kernel (Johan G)
basque.language (jalaguero)
Codacy detected fixes (Mazze)
Locale files refreshed
Prefs/ScreenMode (Kalamatee)
etherlink3.device (Neil)
AROSTCP (Neil)
SAD debugger (Johan G)
AROS build system (Kalamatee)
Kernel (Kalamatee)
freetype.library v6.8 (Kalamatee)
png.library v53.3 (Kalamatee)
jfif.library v52.6 (Kalamatee)
acpica.library v1.12 (Kalamatee)
SysExplorer v0.15 (Kalamatee)
bz2.library v2.3 (Kalamatee)
z1.library v1.9 (Kalamatee)
OpenURL v7.18 (deadwood)
Grub v2.12 (Kalamatee)
codesets.libary v6.22 (Kalamatee)
CUnit v3.5.2 (Kalamatee)
SysMon (Kalamatee)
pcipc.hidd v1.8 (Kalamatee)
efi.resource v1.2 (Kalamatee)
crt.library v5.2 (deadwood)
con-handler v41.9 (Kalamatee)
64-bit support:
mesa3dgl.library, gallium.hidd, softpipe.hidd, IntelGMA
vwmwaresvga.hidd, gallium.library (fixed to work on pre-SSE4.1 CPUs) (deadwood)
Prefs/OpenURL (fixed to work on 64-bit) (Kalamatee)
nvidianet.device (fixed to work on 64-bit) (Neil)
exec.library (bugs: NewStackSwap could damage some registers) (deadwood)
MenuItem.mui (Kalamatee)
AROSTCP (bugs: issues using google service on some setups) (deadwood)
Functional fixes:
gadtools.library (bugs: wrong scrollers in IMP3) (Johan G)
Wanderer (bugs: wrong selection behavior) (Kalamatee)
muimaster.library (bugs: #202, #201) (deadwood)
intuition.library (bugs: SA_Font doesn't override SA_LikeWorkbench) (deadwood)
Prefs/OpenURL (bugs: save of preferences not working, #196) (deadwood)
dos.library (bugs: #211, ReadArgs, GetProcInfo) (deadwood, Kalamatee)
crt.library (bugs: buffer overrun in vfwprintf) (Deremon, Johan G)
Kernel (bugs: 32-bit memory not available on some hardware) (deadwood)
List.mui (bugs: click events are not eaten by class) (Kalamatee)
poseidon.library (bugs: potential race condition) (Kalamatee)
hostgl.library (bugs: not working under WSL) (Kalamatee)
NBitmap.mcc (corrected to work) (Kalamatee)
gfx.hidd (Kalamatee)
Stability fixes:
AROSTCP (bugs: crash when shutdown) (Neil)
C:Break (bugs: crash when wrong process number provided) (deadwood)
diskfont.library (bugs: crash when no fonts directory) (Kalamatee)
Prefs/Wanderer (bugs: crash when closing advanced tab) (deadwood)
crt.library (bugs: seeking on directory handle possible) (deadwood)
intuition.library (bugs: crash when invalid pixfmt) (Kalamatee)
Functional fixes:
icon.library (Russell Shaw)
reqtools.library (bugs: Window pointer check) (Josef Wegner)
Calculator (bugs: trailing 0) (Ivan G.)
gadtools.library (bugs: wrong position of left-aligned object, wrong slider behavior) (ronybeck, r3dbug)
C:Copy (bugs: #179) (jalaguero)
AROSTCP (bugs: fails with fd == -1) (deadwood)
stdlib.library (bugs: wrong value of DST field) (deadwood)
libpthread.a (bugs: not protected against new task getting same address) (deadwood)
AROS One Update:
AROS One System Update:
Add Bitmap_Font Datatypes
Add Outline_Font Datatypes
Add AVIF Datatypes
Add HEIC Datatypes
Add TIFF Datatypes
Add Catalog "Basque" + add Icons
Add StatusBar (Script Enable-Disable ‘Bottom bar’)
Update User-Startup
Moved trackdisk.device to SYS:Storage
Update DOSDrivers PC0 (trackdisk.device is searched for in Storage)
Update AROS One "INFO"
Corrected the size of the stack on APP icons
Update Logos AROS One
AROS One App Update:
QuickPart v0.61
VIM v9.1
Sploiner v1.01
DOSBox v0.74
AROS One Config App Update:
Update Config DOpus4
Update Config ZuneARC (All common file formats are supported)
Update Skins DaySleeper
Update Skins MPlayer
Update config ClickToFront
Add WEBM (Sample Video Files + Icons)
AROS One SDL2-Games
Delugem
Giddy3
Super-Haxagon
TBFTSS
Tilt-N-Roll
Re: AROS One 64Bit v1.2 Realizzato
Messaggioda AMIGASYSTEM » lun ott 27, 2025 2:22 pm
Per chi utilizza OWB 3.0 su AROS 64bit e nota uno sfarfallio dell'interfaccia di OWB, può eliminare la configurazione che ho creato appositamente per OWB, ovvero quello di usare l'impostazioni di ZUNE "Redraw: with clear", su Macchine Virtuali nessun problema il settaggio in questione non crea lacun problema.
Il file da eliminare è "OWB.1.prefs" che si trova in Prefs/Env-Archive/Zune.
Ciò farà sì che OWB utilizzi l'impostazione predefinita 'global.prefs', dove 'Redraw: without clear' è impostata per impostazione predefinita.
Per apportare la modifica immediatamente, senza dover riavviare Aros, è necessario eliminare anche il file 'OWB.1.prefs' che si trova in RAM:ENV/Zune.
Si può anche eliminare il problema modificando direttamente da Zune Prefs scegliendo un comportamento diverso disponibile nello stesso menu.
Messaggioda AMIGASYSTEM » gio nov 13, 2025 12:11 pm
Nuovo aggiornamento per Dopus4 Config su AROS One (32/64/68k): ora è possibile decomprimere 'automaticamente' un archivio LHA. LZH, LZX, ZIP, RAR, 7ZIP, TAR.BZ2, TAR.GZ, TAR.Z, con un semplice doppio clic (LMB), i dati inclusi nell'archivio verranno decompressi nello stesso percorso dell'archivio, mentre con 'Click-M-Click' è possibile visualizzare l'elenco del contenuto dell'archivio, vedere il video allegato.
https://www.youtube.com/watch?v=oVTyOAMaSbU
Messaggioda AMIGASYSTEM » mer nov 26, 2025 4:22 pm
Quelli che vedete nello screenshot sono i puntatori Normal/Busy che troverete nel prossimo AROS One 32/64 Bit e 68k
Alcuni putatori di qualità inferiore sono stati rimossi e molti altri sono mie nuove creazioni.
Se a qualcuno piace un particolare Pointer, possono allegare uno screenshot qui e proverò a crearlo per AROS.
Nell'altro screenshot puoi vedere il nuovo driver video nativo Vmware che funziona su QEmu!
Messaggioda AMIGASYSTEM » dom feb 08, 2026 10:06 am
Per le varie mulazioni creato delle scorciatoie su BoingIconBar dove si potrà avviare le varie emulazioni direttamente dal binario o attraverso script per avviare direttamete le Applicazioni o Giochi.
Per il 32Bit come già citato in altri post sarà possibile avviare le Applicazioni Hollywood Supportate, tutto il software 32Bit è posizionato in apposita cartella nominata AROS-32Bit, vedi screenshot allegato.
https://www.arosworld.org/infusions/for ... ulator.jpg
Messaggioda AMIGASYSTEM » lun feb 09, 2026 10:58 am
Sentitomi con deadwood, e visto che non ci saranno ulteriori aggiornamenti di una certa importanza, ho deciso di iniziare la costruzione della nuova versione 1.3 di AROS One 64bit.
Come affermato da deadwood quest versione rappresenterà un grande passo avanti in termini di usabilità visto le novità riguardo l'emulazione 68k e 32bit.
https://www.arosworld.org/infusions/for ... post_11140
Se qualcuno vorrebbe segnalare qualche anomalia riscontrata nelle versioni precedenti, o richiedere qualche funzionalità mancante in questa nuova versione dovrebbe farlo da subito prima che inizia la costruzione e il test.
