ArosOne-v1.1-x86_64-v11 Realizzato
Messaggioda AMIGASYSTEM » ven ago 08, 2025 4:30 pm
Trovate tutti Download e l'upgrade v1.0/1.1 nel link allegato:
Tante le novità oltre alla stabilità e i miglioramenti del sistema troverete il funzionamento corretto di Dopus4 con la stessa configurazione della versione 32Bit, molti software convertiti da 32 a 64Bit, OWB 3.0, Scheda Video VMware ora supportata Nativamente, e molto altro ancora vedi CHANGELOG.
Functionalities:
C library extended with several wide char functions (Deremon)
SSE2/SS3/AVX accelerated pixel conversion routines (Kalamatee)
Updated several network drivers to work on 64-bit (Neil)
Updates:
Multiview (Russell Shaw, Mazze)
Kernel (Johan G)
basque.language (jalaguero)
Codacy detected fixes (Mazze)
Locale files refreshed
Prefs/ScreenMode (Kalamatee)
etherlink3.device (Neil)
AROSTCP (Neil)
SAD debugger (Johan G)
64-bit support:
mesa3dgl.library, gallium.hidd, softpipe.hidd, IntelGMA
vwmwaresvga.hidd, gallium.library (fixed to work on pre-SSE4.1 CPUs) (deadwood)
Prefs/OpenURL (fixed to work on 64-bit) (Kalamatee)
nvidianet.device (fixed to work on 64-bit) (Neil)
Functional fixes:
icon.library (Russell Shaw)
reqtools.library (bugs: Window pointer check) (Josef Wegner)
Calculator (bugs: trailing 0) (Ivan G.)
gadtools.library (bugs: wrong position of left-aligned object, wrong slider behavior) (ronybeck, r3dbug)
C:Copy (bugs: #179) (jalaguero)
AROSTCP (bugs: fails with fd == -1) (deadwood)
stdlib.library (bugs: wrong value of DST field) (deadwood)
Stability fixes:
Prefs/Wanderer (bugs: crash when closing advanced tab) (deadwood)
crt.library (bugs: seeking on directory handle possible) (deadwood)
intuition.library (bugs: crash when invalid pixfmt) (Kalamatee)
68k support:
exec.library (bugs: wrong CHIP memory alignment for AllocPooled) (Johan G)
sagagfx.hidd updates (Willem Drijver)
Sprites support (DerThore, Johan G, deadwood)
keyboard.device (fix for older games) (ronybeck)
Interleaved bitmap support (DerThore)
Fix handling Copper1 (Johan G)
SDK ABIv11 20250418-1-U1 changes:
collect-aros
Corrected ABI version being written to ELF objects
libpthread.a
Fixed bug triggered by new task getting the same address as one being shutdown
libcrt.a
libstdlib.a
Exposed newly ported wide char functions: fgetwc, fgetws, fputwc, fwprintf, mbrlen, mbrtowc, mbsnrtowcs,
mbsrtowcs, putwchar, vfwprintf, vwprintf, wcrtomb, wcsnrtombs, wcsrtombs, wprintf
libcurl.a
Updated to 7.76.0
libsqlite3.a
Updated to 3.48.0
Re: ArosOne-v1.1-x86_64-v11 Realizzato
Messaggioda AMIGASYSTEM » mar ago 12, 2025 9:56 am
Sul mio sito web ho sostituito l'aggiornamento ArosOne v1.0 a v11, corretto il componente che risolve la regressione sulle CPU Ivy Bridge, corretti Icons OWB, Anche Aros-One-v1.0-Fix è stato aggiornato, ripetere il fix !
Su Tolltype Icona Dopus4 è stato aumentato lo Stack per evitare il Guru quando si copiano dati da una Unità di Rete, sull'icona di OWB invece sono stati aggiunti parametri che velocizzano è migliorano la funzionalità nella Navigazione.
Il Drivers gfx.hidd rende compatibili alcune tipologie di CPU, trovate in questo link la discussione e i problemi riscontrati da alcuni utenti dopo l'aggiornamento ad Aros One v1.1 64bit.
https://www.arosworld.org/infusions/for ... #post_9204
Qui, tuttavia, allego un piccolo archivio che comprende solo i tre componenti riparati!
L'update deve essere utilizzato anche da chi ha installato il nuovo AROS One v1.1 64Bit
Fixed-ArosOne-v1.1.7z
(66.97 KiB) Scaricato 1084 volte
Messaggioda AMIGASYSTEM » dom dic 21, 2025 3:00 am
Disponibile anche su AROS One 64Bit Theme prefs, ora sarà possibile vedere in anteprima tutti i Themes, Installare nuovi Themes, sostituire o salvare il theme prescelto.
Fatto qualche modifica allo script Lua per allineare percorsi dei gadget, questa versione sara disponibile anche su Aros One 32bit e AROS One 68k
