WinUAE 6.0.1 Aggiornata News
Messaggioda MazinKaesar » sab lug 05, 2025 4:59 pm
Nuovo "storico" aggiornamento per WinUAE.
La versione 6.0.0 introduce tantissime novità, un piccolo estratto dal change log:
- Custom chipset emulation (Agnus/Alice and Denise/Lisa) almost completely rewritten. Almost every part of chipset emulation is now internally cycle accurate.
- Custom chipset Denise/Lisa emulation is now running in separate thread for large performance increase in accurate emulation modes compared to previous versions.
- VPOSW/VHPOSW tricks are now cycle-accurately emulated without restrictions.
- Horizontal and vertical blanking and sync start/end, csync, csync equalization pulses, etc are now fully cycle-accurately emulated, both hardwired and programmed. Mixing of hardwired and programmed is fully supported. Agnus/Alice hardwired PAL/NTSC sync generator is almost logic gate level emulated.
- "Display" and Agnus/Alice vertical and horizontal counters are now fully separately emulated, display emulation now works correctly even if Agnus vertical or horizontal is moved backwards or forwards or anywhere (even outside of normal display range), unlimited times per line and/or field.
- All screenmodes (including "Fake" NTSC or similar mode) now count total number of "display" lines and uses it to setup display height. These modes now work even if they do multiple V(H)POSW modifications.
- Interlace detection now uses vsync timing like real displays.
- BPLCON0 ERSY=1 without connected genlock sync stop timing is now accurate. This was faked previously.
- Full AGA hires/shres bitplane and sprite horizontal granularity support. Separate subpixel mode does not exist anymore.
- ECS Agnus/AGA UHRES bitplane and sprite RGA DMA slots (0x78, 0x7a) emulated. Completely useless feature because UHRES can only do some DMA transfers to nowhere. It needs extra hardware that was never implemented. UHRES needs to be emulated because (possibly accidentally enabled) UHRES DMA can steal cycles from copper, blitter and CPU.
Fonte: https://www.indieretronews.com/2024/02/winuae-520-latest-amiga-emulator-release.html
Re: WinUAE 6.0.1
Messaggioda AMIGASYSTEM » mer ago 13, 2025 6:36 pm
Nuova versione v 6.0.1
Tutti i Download:
https://www.winuae.net/
6.0.0 bug fixes:
- Entering and exiting GUI when in fullscreen mode crashed.
- Vertical and horizontal centering works again.
- ECS superhires works again.
- Filter overlay graphics display positioning/size calculation was broken.
- Virtual mouse driver mode was not in sync with host cursor, both RTG and native modes.
- Fast drawing mode with 32-bit Chip RAM fix.
- When switching from emulated graphics board to native programmed mode screen, sometimes native screen had horizontal offset
- In some situations emulated graphics board was not drawn fully, bottom part was blank.
- Add Harddrive: Storage devices containing MBR partition table with RDB in later blocks was not detected correctly.
- Chipset COPxJMP sequence didn't work in some situations.
- Rarely used chipset collision register fix.
- TCP serial mode hang fix.
- OpalVision crash fix.
Other bug fixes and updates:
- PC keyboard without numpad/end key optional translation mode. When enabled, PageUp becomes End (End still works normally). Because cartridge freeze is also PageUp, freeze becomes PageUp + PageDown. END/PageUp + cursor left is Pause and cursor right is Warp mode. (Replacing print screen key). PageUp + 7890/UIOP/JKL<key right of L>/M<key right of M> emulates numpad. Note that numpad emulation is done before PC to Amiga translation which means it does not override enabled numpad joystick option. Option in Input panel. This is registry/ini specific setting (Similar to F11 swap option).
- Copilot key now works as a right Windows (Right Amiga) key. Note that this is a quick hack and causes some (harmless) extra shift and left Windows key presses and releases when Copilot key is pressed and released because Copilot key is weird.
- Added Native/RTG autoswitcher option. Previously all RTG boards without built-in switcher always autoswitched, now it is optional, default enabled.
- ROM scanner now detects CyberStorm MK3/PPC and BlizzardPPC flash rom images using checksums. Address ranges that make ROM image unique (Serial number/board config and boot menu config data areas) are skipped in checksum calculation.
- Built-in AROS ROM updated.
- ROM scanner/loader CD32 1M single ROM handling fix.
- RoboCop 3 dongle emulation fixed.
- Debugger disassembler miscellaneous fixes and updates.
