GemRB 0.8.8
GemRB 0.8.8
Messaggioda MazinKaesar » lun mar 10, 2025 2:47 pm
E' stata rilasciata una versione commerciale di GemRB, l'implementazione open source del motore dei giochi della serie Baldur's Gate. Il pacchetto comprende gli scirpt per installare i giochi direttamente dai CD originali o dai file delle edizioni di Good Old Games e risolve numerosi problemi di librerie mancanti che affliggono la versione free.
Features
This package offers a port of GemRB 0.8.8 to AmigaOS 4.
Installers are included for all four supported games, so that it is easy to install the games directly from the CD/DVD of the PC version without having to ‘pre-install’ on a PC (you can insert the CDs directly into the Amiga during the installation process and the games will be installed).
Alternatively, you can install from the data of the Gog version (but then only with pre-installation on a PC, while a direct installation is possible via the game CDs)
Manual editing of config files, as with versions of GemRB on many platforms, is NOT necessary, the installer already takes care of all this. No shell commands necessary, the game can be installed and then played as normal by clicking on it
Localisations in German, English, Spanish, Italian and Polish are supported
Several important bug fixes that are not available in the old 0.7.2 version and also not in the WOS/MOS 0.8.x version (for example, the ‘Portal Key Bug’ has been fixed and Baldur's Gate 2 is now playable).
GemRB is released under the GPL licence (PC original project: https://github.com/gemrb/gemrb)
No need to search for older .so libraries, the installer takes care of everything
System requirements
Minimum MicroAmigaOne or comparable hardware, recommended is Sam or AmigaOne x1000/x5000 hardware (for Baldur's Gate 2 a Sam or x1000/x5000 is minimum requirement, the other 3 games have slightly lower system requirements), recommended is a filesystem with SFS.
‘Classic’ version of the supported games (Enhanced versions are not supported), either on CD/DVD (recommended, for easier installation) or via Gog (buyers of the Enhanced versions on Gog can download the Classic version for free). The Gog version is available for 15 EUR per game, the CD/DVD versions are often available for less than 5 EUR on eBay and similar platforms.
Link: https://www.amiga-shop.net/en/Amiga-Sof ... :1407.html
