Rilasciato WinUAE 5.2.0
Messaggioda MazinKaesar » mer feb 21, 2024 1:37 pm
Rilasciata la nuova versione del popolare emulatore di Amiga.
    New features/updates:
  • MacroSystem DraCo emulation. Full emulation except V-Lab Motion video board which is totally undocumented. Amiga clone without Amiga custom chips.
  • Picmatic Marbella Vice light gun laser disc arcade game is now fully working.
  • American Laser Games and PicMatic statefile support.
  • Genlock emulation display positioning/scaling updates.
  • Retina Z2 and Z3/Altais RTG board emulation. (NCR 77C22E+ and 77C32BLT SVGA chips)
  • S3 Trio64 PCI RTG board.
  • On screen led font is now configurable, settings in GUI Miscellaneous panel.
  • A2410 updates (Latest Picasso96 driver with DMA mode enabled graphics corruption)
  • All emulated RTG boards now autoswitch (Automatic switch between chipset mode and RTG mode). Previously only RTG boards that have built-in switcher and PCI RTG boards autoswitched.
  • Do not emulate special cases in native chipset screen mode last and first line(s) unless Overscan mode is Overscan+ or higher. (For example OCS Denise top and bottom line mismatched blanking start and end)
  • NTSC mode screen vertical positioning improved.
  • Disk swapper insert/remove cursor position now works as expected. Same image can be inserted in multiple slots.
Sito Ufficiale: https://www.winuae.net/
Visitano il forum: Nessuno e 0 ospiti
