AROS One x86 v2.2 Realizzato
Messaggioda AMIGASYSTEM » mar ott 17, 2023 10:09 pm
Autore: AMIGASYSTEM
AROS One x86 v2.2 Released
AROS One x86 v2.2 include il manuale "Aros One x86" nei formati PDF, GUIDE, HTM e DOC (PC-Windows).
AROS One x86 v2.2 ISO DVD: Download
AROS One x86 v2.2 USB Flash: Download
Update Core ABIv0 :
- InstallAROS (Fix DualBoot)
Update AROS One OS System:
- On USB Image live created link to InstallAROS on Wanderer
- Create Script and related Icon for SMB2-Dismount
- Fix AmiStart menu
- Add AmiStart Prefs Script/Icon "No Backdrop"
- View Font "TTF" and "bitmap fonts" on Wanderer and Dopus4 with a simple double-click.
- New Themes OS4 by Miker
- New and fix Themes AROS One
- Fix Theme (Animation Gadget)
- Improved and enlarged Wanderer top bar
DigiClock 'in transparent mode' is now placed on the top bar of Wanderer
- Add Source MUIClass on Free Pascal IDE
- Created Descriptor Datatypes PAS (Source Free Pascal)
- Created Icon Def_PAS (Source Free Pascal)
- ZuneARC, new AROS One icon-style buttons
- Fix def_ADF.info
- Fix Pointer Prefs (deadwood)
- OWB: Set as search engine DuckDuckGo (faster)
- LilCalendar can now also be found in Utilities
- DiskImageGUI moved to Utilities
- Complete installation packages of 4 types of Disk icons and 4 types of Drawer icons, plus 2 types of Apps icons, all icons were created by me for AROS One. The icons are only available for private use, not allowed to be used on other operating systems.
Update AROS One Apps:
- Loan
- ssh2fs v53.1
- SilkRAW v2.0
- AmiDream v0.2
- Zip.hwp v2.0 (PlugIn Hollywood)
- DigiClock v1.2 (update)
- Image2PDF v2.3
- AmiTranslate v0.3
- LilCalendar v2.7
- V.A.M.P. v3.10
- ArosVNC Single Threaded and MultiThreaded Fix
- WebpTools v1.3.2
- RNOSlides v1.0
- HollywoodSP Spanish Catalog for Hollywood 10
Update AROS One Games:
- Open Jazz Jackrabbit Xmas Full
- Siete Y Media v1.10 (Update)
- Blackjuan Poker Card v1.10 (Update)
- BlackIvan v1.0
- Golf GolfSolitaire v1.0
- Free Abuse v0.71
- Pingus v0.7.6
Re: AROS One x86 v2.2 Relizzato
Messaggioda AMIGASYSTEM » ven ott 20, 2023 6:50 pm
Messaggioda AMIGASYSTEM » mar ott 24, 2023 4:03 pm
Testato con successo "Heroes of Might and Magic II" su AROS One x86 sia la versione nativa tramite Porting, sia la versione DOSBox.
Testato con successo "Heroes of Might and Magic II" anche su OS3 RTG con AfA One, allego entrambi gli screenshot !
Messaggioda AMIGASYSTEM » dom ott 29, 2023 12:56 pm
AROS One x86 v2.2: Play Online MP3 dal Sito AmigaRemix
https://youtu.be/gLJjaD4BgAI
Messaggioda AMIGASYSTEM » mar ott 31, 2023 8:30 pm
2 nuovi giochi disponibili su Aros-Archive, "Passcodes" network word guessing game, e la versione aggiornata di "Pagan Sacrifice".
Entrabi i giochi sono stati testati su AROS One, a chi decide di installarli su AROs One, su richiesta posso creare le icone in stile AROS One.
Re: AROS One x86 v2.2 Realizzato
Messaggioda AMIGASYSTEM » mer nov 08, 2023 8:30 pm
Fract installato su AROS One, Fract Fract è un benchmark di rendering 3D gratuito basato su SDL.
Fract è progettato per fornire risultati imparziali al 100% che corrispondono realmente alle prestazioni della CPU e del Bus di sistema.
Messaggioda AMIGASYSTEM » lun nov 13, 2023 6:02 pm
Installato nella cartella "Extras/Video" di AROS One, e testato con successo su WMWare GLMark, un benchmark OpenGL 3D.
Ora anche GPMark il benchmark Gp2x basato su SDL di Optimus è stato spostato nella cartella "Extras/Video".
Messaggioda AMIGASYSTEM » mer nov 15, 2023 1:47 pm
iConecta v5.0, nuova versione Un piccolo e semplice programma per testare la tua connessione Internet su AROS One.
iConecta controlla se il tuo computer è online o offline (in rosso quando è connesso, in nero quando non è connesso), noltre mostra l'ora della connessione a Internet.
Messaggioda AMIGASYSTEM » gio nov 23, 2023 1:33 am
Su AROS One v2.3 ci saranno alcune nuove caratteristiche, tre nuove cartelle "Benchmarks", "DemoEffects" e "DemoScene" che includeranno software che ho trovato su Archives, Aminet e alcuni siti di sviluppatori.
In "DemoEffects" troverete 40 demo di buona qualità dello sviluppatore italiano "Calogiuri Enzo Antonio", vedi screnshot!
Messaggioda AMIGASYSTEM » dom nov 26, 2023 6:05 pm
Navigare su Internet in WiFi con AROS One x86 senza una Sheda di Rete e WiFi supportato ora è possibile.
Ho scoperto una procedura tramite un utente su come connettere AROS One x86 installato su PC Reale ad un Telefonino con Android installato.
La procedura è semplicissima potete leggerla QUI
Messaggioda AMIGASYSTEM » dom dic 03, 2023 11:44 am
Creato per AROS One x86/68k dei nuovi Descrittori Datatypes per alcuni formati Grafici meno comuni come: TIFF, TARGA, "WEBP " "PPM" (Photoshop), "XBM" (X BitMap) e "XPM" (X PixMap).
Per chi non sa di cosa sto parlando i Dscrittori Datatypes cono quei file che trovate nel percorso "Devs\DataTypes", grazie a questi Descrittori è possibile assegnare una specifica icona (Def_Icons) e uno specifico strumento per riconoscere e aprire un file.
Creare i Descrittori è semplice, in pratica esiste una applicazione che "decomplila" nel formato testo un Descrittore, dove poi è possibile editarlo per creare o modificare il Descrittore, e poi una seconda applicazione che "compila" nuovanmente il descrittore.
Nel descrittore si può utilizzare il riconoscimento attraverso l'estensione, o attraverso una sorta di piccolo codice che si trova inizio file, per alcuni tipi di file e standard per altri varia, in questo caso meglio il riconoscimento per estensione.
Naturalmente è da preferire il riconoscimento attraverso il codice, in questo caso il file sarà riconosciuto anche se non ha una estensione.
Su AROS One ho configuato queste 2 applicazioni in Dopus4, basta un click per decompilare e ricompilare.
Per completare il lavoro occorre creare le Def_Icon per i nuovi Descrittori e inserire nel Tooltypes lo strumento da assegnare alla Icona, più avanti mostrerò anche altri descrittori che ho creato per file Audio, Video, Testo, Compressori, praticamente è possibile far riconoscere al sistema un qualsiasi file anche per una estensione inventata da noi :)
Questi Descrittori e queste Def_Icons da me create funzioneranno bene anche su OS3, OS4 a patto che questi OS avranno i rispettivi Datatypes (Librerie), per intenderci quelli che si trovano nel percorso "Classes\DataTypes".
MOS gestisce in maniera diversa perchè molte associazioni sono configurate dal suo siema interno, per intenderci come fa Dopus5 Magellan o Scalos.
Poi su MOS ci sarebbe anche il problema icone DualPNG non supportate, in pratica se ad una Icona Dual-PNG si modifica il Tooltypes o si cerca di cambiare icona, le Icone Dual-PNG si distruggeranno (diventeranno comuni Icone 4 Colori). Dopo la mia segnalazione, uno sviluppatore MOS ha segnalato allo Staff questo problema, non so se è stato fixato.
Messaggioda AMIGASYSTEM » mar dic 12, 2023 9:32 am
By Christmas I should be able to distribute the new version 2.3 of AROS One, there are a lot of new features in this release, updated Core, new software and a lot of updated software.
In addition I have created new configurations and completed the 4 Icon Sets, as always installable through a simple click, there are now almost a thousand of them.
Among the novelties of AROS One v2.3 there is the presence of 3 new Directories located in "Extras" it's about "Benchmarks", "DemoEffects" and "DemoScene", see screenshot, it's about a lot of very good Demo on RTG screen, many of them came from Amiga world.
