AROS One x86 v2.0 Realizzato
Messaggioda AMIGASYSTEM » gio mar 30, 2023 5:09 pm
AROS One x86 v2.0 Released
AROS One x86 v2.0 include il manuale "Aros One x86" nei formati PDF, GUIDE, HTM e DOC (PC-Windows).
AROS One x86 v2.0 ISO DVD: Download
AROS One x86 v2.0 USB Flash: Download
Update AROS One OS System:
- Create New Set Icons System AfA One Style for the Whole Operating System
- Create number 6 Installer for Set Icons Disk
- Create nuber 4 Installer for Set Icons System
- Create Catalog.italian for ZunePaint
- Fix Theme OS4
- Fixed Theme Pearl Blue
- Fixed GIF Animations
- Add New Pointer 32Bit
- filesysbox.library v54.3
- smb2-handler v53.1
- nvidianet.device v1.1
- Create def_icons for Source file with c, c++, h, o extension
- Create Descriptor webp.datatype, now also recognizes "webp" files without extension
- Update GCC 6.5
- C ++ is not yet available, it will be soon
- Add info version Aros One on (About)
- Add info version Aros One on Barra Wanderer
- New Logo Installer Aros One
- All third-party software is now located in the "Extras/APPS" Folder.
- SMB2 tutorial for setting up a share with Windows, find all the Extras/Internet/SMB2
- Create Set Disk.info for SMB2 volume, they will insntall with one click, after creating the share volume
- Create two new Directories in SYS:System "Hardware" and "Debug" which includes the dedicated software
Update AROS One Apps:
- ComicOn v1.4
- HollyPaint v1.1
- Exutil v1.1.3
- Image2PDF v1.3
- Update WHDLoad v18.8 for WHD_MENU
- MUIInspector v1.0
- Asplit v2.03
- Zip HWP V1.2 (PlugIIn Hollywood )
- XML HWP v2.0 (PlugIn Hollywood)
- Fenachistoscopio v1.0
- WebpTools1.3.0
- RPN Scientific+ V1.02
- SMB2-handler v53.4
- Filesysbox.library 54.3
- Image2PDF v1.4
- Lunapaint v0.6.0
- AnimPlayer v2.4
- IconClone v1.9
- InstallerLG v1.0.2
- DirList v1.1
- IconClone v1.09 Update
- Vintage Song Player v2.50
- AmiSSL 4.12
- Videntium Picta v2.60
- AmiTube v1.4
- Tipografia v1.2
- V.A.M.P. v3.0
- AnimWebConverter v5.10
Update AROS One Games:
- OpenTyrian
- 1941-ExtremeDeluxe
- LazSokoban
- Added three skins for LazSokoban and a script for choosing the skin
- Update Hle Poker Card (Final Version)
- BOFH
- TecnoballZ
Update Core ABIv0 20201110:
Functionalities:
Display free video memory in SysMon where supported (Kalamatee)
Initial work on supporting 3D acceleration in VMWare video driver (Kalamatee)
Implemented network driver for certain nVidia chipsets (Neil)
Initial work on scsi.device (Kalamatee)
Signal CxObject support implemented (Hakan Thorngren)
Support PUBSCREEN argument in Prefs/Appearance, BoingIconBar (Kalamatee)
Support PUBSCREEN argument in Tools/Clock and multiple Prefs applications (Hakan Thorngren)
Support PUBSCREEN variable support in intuition.library (o1i)
Improvements to rendering screen and window title bars (Kalamatee)
Allow video drivers to report display change (Kalamatee)
Prefs/IControl works better on low-resolution screens (Kalamatee)
Set overscan based on information coming from driver (Kalamatee)
Prefs/ScreenMode display more information about video modes (Kalamatee)
Prefs/Palette reworked to be more compatible with Intuition (Kalamatee)
Muimaster.library and built-in classes have been localized (Matthias Rustler)
Initial work on supporting long filenames in afs-handler (Kalamatee)
Palette preferences are now loaded into Intuition (Kalamatee)
Implemented SetMem, Strlcat, Strlcpy in utility.library (Kalamatee)
Implemented VSNPritnf in utility.library (Matthias Rustler)
AmigaPL font collection added (wawa)
Implemented GetKey, AddKBInt, RemKBInt, ElapsedTime in lowlevel.library (Kalamatee)
Part of functionality of SystemControlA in lowlevel.library available (Kalamatee)
Additional font collections added (Kalamatee)
Initial implementation of GetSegListInfo in dos.library (Kalamatee)
Allow loading AmigaOS-style hunk keymaps and fonts on AROS (Kalamatee)
Implemented AssignAddToList in dos.library (Kalamatee)
Implemented v45 datatypes.library functions (Kalamatee)
Introduced webp.datatype (Kalamatee)
Introduced ClockSource subsystem in Kernel (Kalamatee)
Improvements to file system handling in Wanderer (Bo Kopperud)
Public SDK not longer exposes internal AROS headers & libraries (deadwood)
Re: AROS One x86 v2.0 Realizzato
Messaggioda AMIGASYSTEM » dom apr 02, 2023 10:02 pm
Dopo la pubblicazione di AROS One x86 iniziano già gli aggiornamenti per la prossima release, tra i software aggiornati ultimamente c'è RNOTunes v1.1, uno dei migliori Player Musicale visto sui sistemi della famiglia Amiga, in evidenza qualità ascolto e velocità.
Su AROS One troverete anche il mio contributo Grafico, Icone, Sfondi, Skin Pulsanti e localizzazione in Italiano
Queste le caratteristiche:
- Supporta i formati Audio MP3, FLAC, Ogg Vorbis, AAC, AIFF, WAV, Protracker, DigiBooster,
SID, AHX, FastTracker II, ScreamTracker, OctaMED, The Player, NoisePacker,
ProRunner, Oktalyzer, Impulse Tracker, Ultra Tracker, Ice Tracker,
Liquid Tracker, Quadra Composer e molti altri formati
- GUI configurabile con visualizzazione dell'immagine di copertina
- Carica immagini di copertina incorporate e altri metadati da MP3, FLAC e Ogg
File Vorbis
- Scrobbler integrato di Last.fm
- Visualizzazione dei testi
- Modifica le proprietà dell'editor che salva le modifiche in un database locale
- Playlist interne
- Importa formati di playlist comuni ed esporta playlist M3U
- Salvataggio automatico/manuale dell'ultima sessione
- Salvataggio del conteggio di tutti i tempi
- Tune opzione di valutazione
- Ampia funzionalità di selezione dei file
- Opzione di eliminazione file
- Supporto per ARexx, riga di comando e tipi di strumenti
Messaggioda AMIGASYSTEM » lun apr 10, 2023 3:49 pm
Su Youtube un utente di AROS "James Mattson", ha creato un video di 37 minuti su AROS One, mostrando alcune caratteristiche, e complimentandosi per l'ottimo lavoro del Team di AROS!
https://youtu.be/_s_TfmF-_iE
Messaggioda AMIGASYSTEM » dom apr 16, 2023 6:27 pm
Intanto un utente di amigaworld ha installato AROS One 2.0 su MAC OS attraverso QEmu, l'utente è rimasto notevolmente sorpreso nel vedere eseguire AROS One x86 attraverso un semplice Click ;)
https://amigaworld.net/modules/news/art ... oryid=8889
Un'altro utente su Youtube in questi giorni, ha creato un tutorial di 37 Minuti su AROS One 1.9, questo il suo commento:
"Aros one 1.9! Venite a fare un giro su un os dall'aspetto fantastico! Aros è un progetto in corso che continua a migliorare! Ottimo lavoro per il team di aros!"
https://youtu.be/_s_TfmF-_iE?t=10
Messaggioda AMIGASYSTEM » gio apr 27, 2023 11:58 am
Aggiornato il catalog Italiano di Wanderer Prefs, ora su AROS One si potrà utilizzare Wanderer Prefs in Italiano, prossimamente anche il nuovo Catalog Italiano di Zune Prefs sarà disponibile in Italiano.
Fatto questa operazione perchè la vecchia versione del catalog Italiano di queste due app di sistema erano obsolete, e non non essendo più supportate venivano ignorate lasciando tutto nella lingua nativa "Inglese"
Ringrazio Samo79 per aver vericato e corretto qualche erroriedi traduzione !
Messaggioda AMIGASYSTEM » sab apr 29, 2023 12:16 am
Anche i catalog Printer prefs e PSI Prefs sono stati tradotti in Italiano, non sono finite le traduzioni.
Appena saranno utilmate tutte le traduzioni, saranno disponibili per tutti, saranno ben accetti segnalazioni per eventuali errori di traduzione.
Finiti i test tutti i file "catalog" e i file "ct" tradotti saranno disponibili per tutta la comunità AROS x86/68k
Messaggioda AMIGASYSTEM » lun mag 01, 2023 10:32 pm
Il lavoro di traduzione continua, tra ieri e oggi tradotto i catalog "Wimp", ReqTools Prefs, e ASL Prefs.
Vorrei ricordare che i Catalog AROS x86 sono gli stessi utilizzati da AROS 68k, ApollOS, V4 Vampire che fa uso di AROS 68k
Se qualche utente "Italiano" vorrebbe testare le traduzioni, e magari trovare qualche mia traduzione non adeguata, può contattarmi in PM.
Considerare che io ho utilizzato stringhe abbreviate e sisntetiche, onde evitare che le GUI possano ingrandirsi notevolmenete
Messaggioda AMIGASYSTEM » mar mag 09, 2023 4:46 pm
Utente e sviluppatore Morphos prova AROS One, e lo trova super veloce ... tradotto queste le sue affermazioni su AROS One:
SÌ. Mi piace perché sembra AmigaOS su un'autostrada. [modalità top secret attiva] Il team IMHO MorphOS dovrebbe passare a x86.[modalità top secret disattivata]
Per me personalmente AROS è in realtà AmigaOS su una strada aperta.
Le poche cose importanti che, IMHO, rendono unico Amiga sono: configurabilità di quasi tutto (con particolare attenzione al MUI), ram disk, schermi.
Qui trovate i sui post su AROS one:
https://ae.amigalife.org/index.php?topic=1119.0
https://ae.amigalife.org/index.php?topi ... g16291#new
Questi invece sono duet tutorial su AROS One postati su Youtube da James Mattson
https://youtu.be/Bfs2iLlTcXE
https://youtu.be/4PvICVNBuGw
Messaggioda AMIGASYSTEM » sab mag 20, 2023 5:40 pm
Terminate le traduzioni in italiano dei catalog, sono 43, questi sono gli utimi tradotti !
Boot
ASL library
Clock
DiskimageDevice
Dos
Font
Format
Keyshow
Muimaster
Palette
Pcitool
ScreenGrabber
SysMon
Wbrename
Se qualche italiano vorrebbe testare e trovare qualche errore di traduzione ne sarei felice, ci sono catalog come per esempio "Plalette" che non è semplice da tradurre, lo dimostra il fatto che molti traduttori di altri paesi hanno fatto traduzioni diverse fra loro.
Messaggioda AMIGASYSTEM » lun mag 22, 2023 9:28 am
Aggiornato su AROS One il command LHA alla versione 1.14i
LHa per Unix con una manciata di modifiche per renderlo più simile all'implementazione per AmigaOS di Stefan Boberg e altri.
AmigaOS di Stefan Boberg et al. I permessi e i commenti dei file
commenti sono conservati, i caratteri jolly Amiga sono supportati e la directory di destinazione dell'estrazione
di destinazione dell'estrazione può essere specificata senza usare l'alieno Unixdklsfjiss.
È basato su LHa per Unix con Autoconf di Koji Arai.
Tradotto con www.DeepL.com/Translator (versione gratuita)
Messaggioda AMIGASYSTEM » gio mag 25, 2023 12:51 am
Ho Compilato su AROS One x86 la nuova versione di WildMIDI v0.4.5, con questa versione ora è possibile riprodurre una lista di Midifile in successione, migliorato anche lo script, ora dal File Request può fare una scelta multipla (vedi screenshot).
Il Player "da Shell " WildMidi esiste anche per OS3, OS4 e MOS
La nuova versione 0.4.5 di WildMidi da me compilata, utilizzerà gli strumenti musicali contenuti nella famosa cartella "Timidity", e potrà essere utilizzato come strumento nel tooltypes icona della Def_midi.info
Messaggioda AMIGASYSTEM » dom mag 28, 2023 9:33 pm
Creato 4 Skins per "AROSAmp", fatto anche qualche modifica sulle dimensioni, i testi delle canzoni uscivano fuori dal campo prestabilito.
Spero che venga continuato lo sviluppo, AROSAmp è un ottimo strumento per ascoltare una Playlist di MP3.
Gli Skins si cambiano manualmente, in questa versione Alfa non è acora abilitata la funzione "cambia skins", ma su AROS One creerò degli script in modo da avviare AROSAmp con lo Skin preferito.
Preciso che Gli Skin di WinAMP, AmigaAMP non sono compatibili "AROSAmp", ma devono essere creati o modificati manualmente partendo da uno skin già creato
Messaggioda AMIGASYSTEM » ven giu 02, 2023 9:22 am
Completato il set Skins per AROSAmp per AROS One x86 (tutti creati a mano), son 12 i nuovi Skins, di cui uno Lite (vedi video allegato).
Inoltre sono riuscito a correggere gli artefatti grafici, ora le GUI appaiono perfette, nel video è possibile vedere i 12 nuovi Skin caricati tutti e 12 contemporaneamente, più le 3 Skins di default.
AROSAmp, anche se è una versione alfa, è molto stabile, non funzionano solo il gadget uscita e il cambio Skin (non implementato), puoi comunque uscire dal Menu e cambiare gli Skin dagli script da me creati (vedi video).
Funziona bene la PlayList e il programma di preferenze.
Tutorial Video AROSAmp:
https://youtu.be/vgY3j8tTdz8
Messaggioda AMIGASYSTEM » lun giu 05, 2023 4:37 pm
Finito lo script per cambiare sfondi e pulsanti su MPlayer, allego un piccolo video tutorial completo su come fare il cambio di temi.
Aggiungo che qualsiasi sfondo e pulsante scelto sarà salvato come settaggio predefinito!
https://youtu.be/FaDRwnKkW3U
Messaggioda AMIGASYSTEM » sab giu 10, 2023 10:10 pm
Creato Nuovi "Temi Pulsanti" per OWB, allego piccolo Tutorial Video che mostra tutti i Temi disponibili e gli script per cambiare i al volo i Temi attraverso un semplice clic su apposita icona.
https://youtu.be/2ZkvuK1-7eg
Visitano il forum: Nessuno e 59 ospiti
