AnimWebConverter v5.00 AROS x86
Messaggioda AMIGASYSTEM » mar nov 08, 2022 8:29 pm
Autore: Juan Carlos Herran Martin:
AnimWebConverter v5.00 AROS x86: Download
AnimWebConverter è programma localizzato in Italiano, Spagnolo, Inglese. Francesee Polacco e Tedesco, che consente in maniera semplice di riprodurre o convertire le animazioni.
AnimWebConverter supporta i seguenti formati: ANIM, GIF, APNG/PNG, YAFA e ILBM (solo modalità 5), AVI (compressione jpeg di movimento), inoltre puoi cambiarne le dimensioni, la velocità o estrarne i Frame
Improvements version 5.00::
1. New language available:
- Deutsch by Lars Brämer & G. Translator.
2. Compiled with last Hollywood version 9.1.
3. Menu bugs were fixed with the new Hollywood 9.0.
4. Added to save animation in iff with mode 5 compression from Hollywood.
5. Improvement when you save gif or lbm file, you can choose the colors
palette among 8-16-32-64-128-256.
6. Improvement when you save the avi file, you can choose Frames Per
Second and Quality/Compression video, by default 25 FPS and 100%.
7. Added the options of enlarge or reduce the animation using the
percentage until 999%, suggested by Adam Mierzwa.
