Odyssey 1.23 r5 RC2 OS4.1
Messaggioda AMIGASYSTEM » dom gen 02, 2022 1:31 pm
Odyssey: Nuova versione del famoso Browser, questa è una versione ufficiosa, passato qualche giorno di test e in mancanza di segnalazioni di problemi importanti verrà distribuita ufficialmente su OS4Depot.
Odyssey 1.23 r5 RC2: Download
Novità di questa versione:
-- rebuild with the latest: GCC 11.1 and new latest OS4 SDk (so new MUI, DOS, EXec, pthreads and co). As one of the positive results is the size of the binary start to be smaller on 3MB (60MB instead of 63MB)
-- new youtube script from MorphOS's devs (ASiegel), so to make accelerated video player works with changed youtube.
1). Delete in your scripts Youtube Fullscreen Fix and Youtube HTML5 Converter. Restart Odyssey and add again but this time new scripts (so allowed sites and stuff will be new ones)
2). Add to URL preferences http://youtube.com with spoof as Ipad 13.2.3. So it will always switch to the mobile version
3). Now on any video when you click on any part of the video, you will have in the right/bottom area gadget to expand the video: clicking on it will bring our accelerated media player back.
-- Updated curl-ca-bundle.crt (https://curl.haxx.se/ca/cacert.pem , 26 Oct 2021)
-- Updated to Curl 7.80.0 (10th of November 2021)
-- Updated to OpenSSL 1.1.1m (14-Dec-2021) (thanks MickJT for tips)
-- Updated to SQLite 3.34.0 (2020-12-01) instead of old v3.7.5 (2011-02-01). Port done by Steffen Gutmann
-- Updated to libFreeType2 2.11.1 (02-Dec-2021)
-- Updated to libXML2 2.9.12 (13-May-2021)
-- Updated to libWebP v1.2.2-rc1 (18-Dec-2021)
Re: Odyssey 1.23 r5 RC1 OS4.1
Messaggioda MacGyverPPC » dom gen 02, 2022 10:32 pm
Bene :rock:
Messaggioda ghillo » dom gen 02, 2022 10:37 pm
Ha già rilasciato la RC2 , io la sto provando e sembra funzionare bene mi sembra leggermente piu' veloce e qua su AmigaNews noto che prima non so per quale motivo avevo la cpu occupata quasi completamente ed ora è a metà (non so il perchè visto che su altri siti non ho questo problema) ,speriamo che lo sviluppo vada avanti , adesso lo voglio provare anche con quei siti che mi davano un po di problemi tipo quello della banca e delle poste.
ghillo
Messaggioda AMIGASYSTEM » dom gen 02, 2022 11:12 pm
ghillo ha scritto:Ha già rilasciato la RC2 , io la sto provando e sembra funzionare bene mi sembra leggermente piu' veloce e qua su AmigaNews noto che prima non so per quale motivo avevo la cpu occupata quasi completamente ed ora è a metà (non so il perchè visto che su altri siti non ho questo problema) ,speriamo che lo sviluppo vada avanti , adesso lo voglio provare anche con quei siti che mi davano un po di problemi tipo quello della banca e delle poste.
Questo sito include molta grafica con risoluzioni immagini medio alte, probabilmente ora Odyssey le gestisce in modo diverso. Comunque la pesantezza di un sito dipende da quello che ci trovi, prova a digitare "youtube.com" dove sicuramente noterai un notevole rallentamento visto le tante anteprime video. i Browser più vanno avanti più diventano lenti questo è dovuto alle funzioni aggiunte per essere compatibile con i nuovi standard.
Aggiornata la news alla versione 1.23 r5 RC2
