A Week In AROS...
A Week In AROS...
Messaggioda AMIGASYSTEM » dom feb 21, 2016 7:21 pm
Nuovo topic dedicato alla programmazione settimanale dei lavori svolti dai programmatori AROS, partendo da Gennaio 2016.
Lo scopo della discussione è quella di rendere noto il lavoro svolto dai vari sviluppatori AROS durante il loro tempo libero.
04 Gennaio 2016
- Dispatchers in Scalos Boopsi classes are now working correctly on AROS 68k (wawa)
- Dispatchers in Scalos MUI classes are now working correctly on AROS 68k (wawa)
- Definitions of structures used by animation.datatype are now binary compatible (Kalamatee)
- A fix has been implemented in calling hooks in realtime.library (Kalamatee)
Ultima modifica di AMIGASYSTEM il mer apr 20, 2016 6:29 pm, modificato 5 volte in totale.
Re: A Week In AROS...
11 Gennaio 2016
- Work started on porting AROS to STM32F7 DISCOVERY board (DizzyOfCRN)
- Window size has been fixed in MultiView (polluks)
- Static C library has been extended with a number of math functions (Kalamatee)
- Fix for buttons being stuck after mouse button is released has been implemented in Area MUI class (neil)
- Ability to use GCC 5.3.0 as a cross compilers has been added (DizzyOfCRN)
- Version of used datatypes is used visible in MultiView about window (Kalamatee)
- Development started on animation.datatype (Kalamatee)
- Initial versions of anim.datatype and gifanim.datatype have been introduced (Kalamatee)
- Initial version of mpegvideo.datatype has been introduced (Kalamatee)
- DOS's FindSegment function has been fixed to be compatible with original (neil)
- animation.datatype is now available in nightly builds (Kalamatee)
- Work started on tapedeck.gadget (Kalamatee)
- Unpacker for anim-j format has been added to anim.datatype (Kalamatee)
- tapedeck.gadget now handler input and changes color based on mouse input (Kalamatee)
- tapedeck.gadget is integrated with animation.datatype (Kamalatee)
- Listtree.mcc no longer causes memory trashing by freeing freed memory (deadwood)
- tapedeck.gadget now correctly handles state based on input (Kalamatee)
Ultima modifica di AMIGASYSTEM il dom feb 21, 2016 7:27 pm, modificato 4 volte in totale.
Messaggioda AMIGASYSTEM » dom feb 21, 2016 7:22 pm
18 Gennaio 2016
- animation.datatype player is paused when handling gadget input (Kalamatee)
- Animations can now be started and paused via the UI (Kalamatee)
- tapedeck.gadget mentains a fixed height (Kalamatee)
- animation.datatype now creates a player that does not interfeer with other players (Kalamatee)
- Fix for leaving semaphore in a locked state has been implemented in anim.datatype (Kalamatee)
- Datatype for ANIM has the file type detection improved (Kalamatee)
- Frame handling in animation.datatype has been improved (Kalamatee)
- Autodocs available at http://www.aros.org has been refreshed (mazze)
- List MUI class has been fixed not to have images overlap text (neil)
- datatypes.library now supports code embedded in datatype for type detection (Kalamatee)
- anim.datatype now supports anim-4 format (Kalamatee)
- Pen allocation in EHB mode has been fixed in animation.datatype (Kalamatee)
- Access to pen array in animation.datatype is now thread-safe (Kalamatee)
- Work on support for playing embedded sounds data in anim.datatype has started (Kalamatee)
- BWins custom MUI class now works on AROS 68k (wawa)
- Improve rendering of animation.datatype to high/true color screen (Kalamatee)
- tapedeck.gadget no longer flickers when rendering (Kalamatee)
- ANIM-5 format now correctly renders (Kalamatee)
Ultima modifica di AMIGASYSTEM il dom feb 21, 2016 7:38 pm, modificato 6 volte in totale.
25 Gennaio 2016
- MultiView is now used for animation datatype (mazze)
- Work on modularization of SysExplorer started (Kalamatee)
- MultiView is now showing more details about data objects (Kalamatee)
- Fix for accessing freed memory implemented in Listtree MUI class (deadwood)
- MultiView is now presenting more information about images and animations (Kalamatee)
- animation.datatype is reworked to speed up playback (Kalamatee)
- Intuition no longer crashes when menu name is not provided (Kalamatee)
- Rendering of animations in EHB mode has been fixed (Kalamatee)
- anim.datatype now correctly supports anim-8 unpacking (Kalamatee)
- Further fixes to anim-3 format implemented (Kalamatee)
- Implementation of jumping to a selected frame in animation.datatype started (Kalamatee)
- Hooks are now correctly called from within realtime.library (Kalamatee)
- tapedeck.gadget handles input on progress bar correctly (Kalamatee)
- Forward/rewind is now working in animation.datatype (Kalamatee)
Ultima modifica di AMIGASYSTEM il dom feb 21, 2016 7:33 pm, modificato 1 volta in totale.
Messaggioda AMIGASYSTEM » dom feb 21, 2016 7:23 pm
08 Febbraio 2016
- 64-bit fixes have been applied to Urltext, BWin and TheBar MUI classes (Kalamatee)
- Performance of part of rendering of decoration system has been improved (Kalamatee)
- Alpha blitting in IntelG45 driver in now improved (Kalamatee)
- Fixes for 68k compatibility have been added to Calculator (wawa)
- Which command has been fixed only to find files (mazze)
- Romania keymap now available in Input preferences (polluks)
- Multiview is now able to scroll with space and backspace (mazze)
- Compatibility of Which command has been improved (mazze)
Messaggioda AMIGASYSTEM » lun mar 14, 2016 8:51 pm
15 Febbraio 2016
- A crash in TLSF memory manager has been fixed (mschulz)
- Amiga.lib no longer depends on C library (neil)
- AvailFonts function of diskfont.library now supports NULL parameter (mazze)
Messaggioda AMIGASYSTEM » lun mar 14, 2016 8:53 pm
22 Febbraio 2016
- AROS x86_64 is now using large memory model and allows putting executable above 2GB barier (mschulz)
- Skip command will no longer enter infinite loop when a matching Lab/EndSkip can't be found (neil)
- AROS x86_64 now allocates more than 4GB of RAM (mschulz)
- Wanderer now correctly displays available memory when > 4GB (mschulz)
- Avail command has been corrected to work on x86_64 AROS (Kalamatee)
- FormatString function of locale.library now supports displaying of IPTR type (mschulz)
- AROS monitor drivers are now correctly detected during boot on AROS linux hosted (Kalamatee)
- Autodocs documentation has been updated from source code (mazze)
- Lunapaint is now part of AROS Contrib repository (mazze)
- Hebrew keymap has been added (polluks)
- More utility now correctly handles files with more than 32768 lines (mazze)
- Dir command now allows interactive directory walking (mazze)
- FryingPan has been corrected to work on X86_64 AROS (Kalamatee)
Messaggioda AMIGASYSTEM » lun mar 14, 2016 8:54 pm
29 Febbraio 2016
07 Marzo 2016
- Moves of MUI Windows are no longer wrongly interpreted as resizes (stegerg)
- Internal MUI classes in Zune preferences now have a default picture (mazze)
- Work on switching AROS to GCC 6+ started (Kalamatee)
- Complete AROS sources are beeing adjusted to work with GCC 6.0 (Kalamatee)
- Complete Contrib and Ports sources are beeing adjusted to work with GCC 6.0 (Kalamatee)
- Memory leak in Zune preferences related to icon images fixed (mazze)
- Blits on AROS Amiga RTG driver in cases of simple copies have been speed up (stegerg)
- AROS Amiga RTG driver has been extended to handle bitmaps outside of VRAM (stegerg)
- FAT filesystem handler is now fully ROMable (jmcmullan)
- Definition of TagItem has been corrected to work on AROS x86_64 (Kalamatee)
- A possible overflow in BltTemplate function of graphics.library has been fixed (stegerg)
- Value range in AROS Amiga RTG driver in PutTemplate method has been fixed (stegerg)
- A fix for passing wrong value of Screen in Wanderer has been implemented (Kalamatee)
- Stability of AROS Amiga RTG driver improved by adding locking (stegerg)
- Blocker issue causing wrong optimization in intuition.library under GCC 6.0 has been found and fixed (Kalamatee)
- Register-spill issue for ScalePixelArray function under 68k has been worked around (jmcmullan)
- Boot delay for USB boot devides now works correctly (Kalamatee)
- Bug related to write commands in FFS file system and partition.library has been fixed (Kalamatee)
- Correctly preserve A5 register on 68k when compiling with GCC 6.0 (jmcmullan)
- FKey commodity can now execute AREXX scripts (mazze)
- A bug in color mapping has been fixed (stegerg)
- Next round of x86_64 fixes in FryingPan has been implemented (Kalamatee)
- A bug has been fixed in LUA MUI library (Kalamatee)
- Memory trashing bug has been fixed in XAD CAB library (Kalamatee)
- LZO library has been updated to version 2.09 (Kalamatee)
- Scout, Wazp3D, BWins class and Scalos has had bugs related to 64-bit compatibility fixed (Kalamatee)
- ATA driver no longer crashes on 68k under low memory condition (jmcmullan)
Messaggioda AMIGASYSTEM » mer apr 20, 2016 6:27 pm
14 Marzo 2016
- Scalos is being adapted to work on 64bit (Kalamatee)
- Work started on tool that converts images to C source (mazze)
- RawDoFmt and FormatString functions now have a datastream definition that is working on all architectures (jmcmullan)
- Zune prefs now has icon images for certain internal classes (mazze)
- Work of adjusting AROS sources to GCC 6 continues (Kalamatee)
- AROS repository reached 52000 commits
- LazyMines game is no longer crashing on startup (mazze)
- Italian translation for Wanderer has been fixed (impulse)
- DiskImage GUI has been fixed to work on 64-bit (jmcmullan)
- A crash in diskimage.device has been fixed (jmcmullan)
- Initial seed for C library rand function calculation has been improved (Kalamatee)
- FormatString and LocRawFoFmt has been extended with ARM anx x86_64 specific patches (jmcmullan)
- LazyMines game have been extended with install script (polluks)
- A bug in MUIM_List_Remove of MUI List class has been fixed (mazze)
21 Marzo 2016
- Diffutils have been updated to version 3.3 (Kalamatee)
- pthread library has been extended with pthread_detach and pthread_getschedparam (deadwood)
- MUI Colorfield, Cycle and Pendisplay classes received a fix for modifying passed parameters (Kalamatee)
- Corrupted image in About MUI class on 64-bit has been fixed (mazze)
- Chunkyimage class has been corrected to work on 64-bit (mazze)
- FreeGadgets function of gadtools.library has been made more compabile in regards to message handling (stegerg)
- AROS Amiga RTG driver has received threading and VMRA<->RAM swapping improvements (stegerg)
- A crash has been fixed in MUIMine game (mazze)
- Initial work on adding Clang/LLVM as optional cross compiler has started (Kalamatee)
- A bug has been fixed in textengine of muimaster.library (mazze)
- C:Info command now works correctly under 64-bit (jmcmullan)
28 Marzo 2016
- Work on being able to use Clang/LLVM to compile AROS continues (Kalamatee)
- Find tool now uses MUI requesters and supports localization (mazze)
- It is now possible to search for content in Find tool (mazze)
- Possible memory overrun has been fixed in unard (mazze)
- A fix has been implemented in MUI Process class (mazze)
- Find tool now uses background process to do the directory scanning (mazze)
- Various catalog files have been reviewed and updated (mazze)
- Initiated work for supporting ARM 64-bit architecture (Kalamatee)
- Poseidon USB stack now compiles for AROS 68k (Kalamatee)
- Crash during initialization of MUI List class has been fixed (o1i)
- animation.datatype behavior has been updated (Kalamatee)
- Zip and Zoom clients of xad.library have had out of bounds access fixed (Kalamatee)
- Norwegian catalog has been added and German catalog has been fixed in Yahzee game (polluks)
- Work started on GUI file searching tool integrated with Wanderer (mazze)
Messaggioda AMIGASYSTEM » mer apr 20, 2016 6:28 pm
04 Aprile 2016
- MadMatrix game is now part of AROS Contrib repository (mazze)
- FKey commodity received a small UI update (mazze)
11 Aprile 2016
- MinAD application is now part of AROS contrib repository (mazze)
- It is now possible to globally disabled lto optimization (Kalamatee)
- ffmpeg library in version 3.0.1 is now part of AROS contrib repository (Kalamatee)
Messaggioda AMIGASYSTEM » sab apr 30, 2016 11:42 am
18 Aprile 2016
- SMB file system received a 64bit fix (Kalamatee)
- ScummVm has been updated to version 1.8.0 (mazze)
- MilkyTracker has been added to AROS ports repository (mazze)
Torna a AROS e compatibili
