AspireOS v.1.6 Nuovo aggirnamento
Messaggioda AMIGASYSTEM » gio feb 02, 2012 3:18 am
Nuovo aggiornamento anche per AspireOS, allego le novità riportate:
Fonte Notizia E Downolad
AspireOS "Let there be rock"
This weened it will be out and it will be a new ISO. I will not release any update this time. Exsisting AspireOS users would have to either take backup of old installation and install from scratch or copy files from CD over old installation.
AspireOS "Let there be rock" will be more global. I have included all drivers found in other distributions or AROS night build. Developer files are also included so you now have the choice to install it from the installer. New with the release is that Games are not included, it will come in a sepperate archive. This is to save space. I like AspireOS to be in AROS archives and on Aminet where files size are limited.
Anyway. This is by far the most complete AspireOS release ever. With the work from our great Developers and first of all the great papercuts project, we now have a much better user interface where all normal file operations work as expected. We can now even iconify programs that supports it.
AspireOS "Codename Let there be rock"
I hope by end of month there will be new AspireOS release called "Let there be rock".
As posted before, it will include new ISO. With the fantastic work from our Developers, the user experince is better than ever.
AspireOS will not be so restricted anymore (ACER aspire one etc.). AspireOS should with this release work with as much hardware as any alternative AROS Distribution or AROS night build does.
I still recommend ACER aspire one though, for troublefree operation.
There are simply so much happening and some changes to Wanderer break some old stuff. It is simply a need for a whole new ISO. All updates after that must be made from that ISO codename: Let There Be Rock. AspireOS codename: Back in Black will be no more.
Come fare gli aggiornamenti da DirOpus4
(come si faceva una volta, a mano ...)
Torna a AROS e compatibili
