A Week In AROS...
Re: A Week In AROS...
Messaggioda AMIGASYSTEM » lun mag 09, 2016 8:29 pm
Maggio 2016
- Potrace has been updated to version 1.13 and ZuneView has been updated to version 0.22 (mazze)
- Compatibility of Amiga chipset driver has been increased (twillen)
- Serbian language definition has been added (polluks)
- Nightly builds of x86_64 AROS are available again (deadwood)
- Work continues on compiling AROS with LLVM/Clang (mschulz)
Messaggioda AMIGASYSTEM » lun ago 22, 2016 5:54 pm
Giugno 2016
- Installing grub into graphics mode works again (deadwood)
- Autodocs documentation has been updated from source code (mazze)
- A crash in Network preferences related to handling of SMB shares have been fixed (deadwood)
- smb-handler no longer crashes during exiting (deadwood)
- AROS C library is now supports TIOCGWINSZ argument for ioctl function (o1i)
Messaggioda AMIGASYSTEM » lun ago 22, 2016 5:55 pm
Luglio 2016
- Stty can now print the rows/columns of the terminal/shell console (o1i)
- Taiwan country configuration is now available in AROS (polluks)
- Ioctl function of AROS C library has been fixed to work on AROS 68k (neil)
- CPU calibration has been fixed in DiskSpeed tool (neil)
- German catalog has been added to DiskSpeed tool (polluks)
- Native GCC compiler works again (deadwood)
- FormatString function in locale.library is now correctly returning remaining data stream (deadwood)
- GIF images are now correctly supported by datatypes.library (deadwood)
- Performance of ProcessPixelArray function has been improved (deadwood)
- A bug in MUI List class has been fixed (deadwood)
- Abcm2ps has been updated to version 8.11.7 (mazze)
- ZuneArch 1.4b compiles again (mazze)
- Shell Delete command is now correctly handling QUIET parameter (polluks)
- EasyReqest and BuildEasyRequest functions of intuition.library are now x64/arm compatible (deadwood)
- Povray and xad_rar now compiles with gcc 6.1.0 (wawa)
- Vusbhci.device compiles again (dizzyofcrn)
Agosto 2016
- AROS 68k kernel has been adjusted to work when compiled with GCC 6.1 (twillen)
- ScreenMode preferences now correctly set default width (deadwood)
- autoconf and automake are now enabled in nightly builds (deadwood)
- An optimization code in dos.library with GCC 6.1 has been fixed (Kalamatee)
- Index out of bounds bug has been fixed in Quake (Kalamatee)
- SysExplorer is now part of nightly build again (Kalamatee)
- AROSTCP no longer crashes when logging is enabled (o1i)
- Work on porting OpenSSH 7.3 has started (deadwood)
- C:MakeDir now correctly sets RC (polluks)
- Tests for MUI List class are being extended (neil)
- Locale preferences program now correctly closes configuration file (Kalamatee)
- A bug in date parsing in locale.library has been fixed (Kalamatee)
- Crashes in sprite operations in graphics.library fixed (Kalamatee)
- DrawGList function in graphics.library now better handles BOB sprites (Kalamatee)
- Several preferences application have had Czech catalog added (mmartinka)
- Presets for english and german locales are now available (Kalamatee)
- German catalog has been added to Prefs/Boot, ChocolateCastle (polluks)
- Czech catalog for Wanderer has been updated (mmartinka)
- openssl library has been updated to version 1.0.1t (deadwood)
- A bug has been fixed in the hosted USB driver (dizzyofcrn)
continua ...
Torna a AROS e compatibili
