Varie MorphOS
Re: Varie MorphOS
Messaggioda Jambalah » sab feb 11, 2012 6:34 pm
Grazie Miky! :felice:
Propongo un'altra anteprima, dato che da quella skin ho disegnato una decina di varianti:
Ognuna di esse è fornita di relative impostazioni MUI, chiaramente mescolabili e/o modificabili a piacimento. Ultimi ritocchi e via a uploadare!
Jambalah
Re: Varie MorphOS
Messaggioda divina » dom feb 12, 2012 8:52 pm
thread aggiornato con ultime novità interessanti: Gribouillis 3.1.500 , PyMUI 0.6, SVN r254 , NetPrinter 1.15 , Blender 2.61 r169 update , Prédateur 2.2.1 UCI chess engine , FPSE 0.10.3 emulatore , ScummVM 1.4.1
Re: Varie MorphOS
Messaggioda divina » ven mar 09, 2012 10:54 pm
thread aggiornato con ultime novità interessanti: Blender 2.62, Grunch 1.36, Hollywood 5 e nuovi plugins, AmigaMark 1.1 benchmark program ed utilities/tools, OpenOfficeViewer 0.0.8
Re: Varie MorphOS
Messaggioda divina » sab mar 24, 2012 9:17 pm
Sqrxz 3 game, MUIbase 2.11, Hollywood 5 nuovi plugins, OpenOfficeViewer 0.0.10
Re: Varie MorphOS
Messaggioda divina » gio apr 26, 2012 11:41 pm
thread aggiornato con ultime novità interessanti viewtopic.php?f=40&t=14653&p=171173#p171173
informazioni recenti in merito a MorphOS 3.0 24/04 da Guido Mersmann, alias @Geit
There are no problems with the hardware, nor is the MorphOS team is not able!
The release was planned for December but was postponed because a complete package at the time was possible.
The reasons are much more banal than the ones listed here. Developers had accidents were professionally so occupied and there were other logistical problems that have just brought the development clearly in default.
The fact that the announced devices are old, makes a driver development any easier, especially as the "infrastructure" needed a lot of laptop components, it did not exist to date on an Amiga system. There are sensors, display brightness control, fan controllers, battery management, Touchpadunterstützung, etc, whose hardware is partially controlled via bus systems, in turn need the driver. Important drivers are real and not a patch with Linuxgemurkse in the startup-sequence. Only the system remains small and fast. Everything should be clean eringebunden into the existing system philosophy. The experience "MorphOS" should be on the laptop the same as on a Pegasus or a mini.
There are not "only" four laptop models known to be supported. These models have up to 6 different revisions, all of which have their own idiosyncrasies again. Here the sound is different because you have to turn the network and there is the display brightness differently regulated, and so on.
Then there are the normal work on the OS bugs fixed, extend existing components and add new applications and tools to customize installer, make local, writing documentation, collect release forms. Beta versions are distributed to the testers and bugs fixed again. In parallel, the SDK will be maintained and kept current.
The MorphOS team tries to put a round thing on the CD. This includes icons and neat presentation.
Stable running MorphOS for ages on the new machines. Not for nothing, almost all developers have been working hard on exactly these computers, so it can be assumed that the PowerBook to the Pegasus are probably best be tested systems.
Last but not least. It is MorphOS MorphOS 2.x. 3 and not The update will be bigger and even if it's not all what was planned would create in 3.0 are still plenty of things in the pipeline, which will surprise some people still so in 2012.
The problems are eliminated and the entire team is working hard on a release as soon as possible. This is however by no means pass on cost of quality.
Geit
e da Harry Sintonen, alias @piru, 04/04/2012
Yep. For instance we're currently in progress of finalizing MorphOS 3.0 release. We already have plans for 3.1, too.
dal Geit's party 23/03 25/03 (PowerBook G4)
Re: Varie MorphOS
Messaggioda Kyle » ven apr 27, 2012 6:46 am
Dovrebbero quasi esserci allora.
Spero per voi utenti che per maggio arrivi, così Cip potrà finalmente registrare la sua copia :felice:
Re: Varie MorphOS
Messaggioda cip060 » ven apr 27, 2012 1:22 pm
Che tra l'altro compio gli anni!!
Apro un bounty per la registrazione di MOS
donate il piu' possibile :ride: :ride:
Prometto che non avro' piu' discussione con i soliti ignoti :ride:
Re: Varie MorphOS
Messaggioda Mabo81 » ven apr 27, 2012 2:10 pm
cip060 ha scritto:Che tra l'altro compio gli anni!!
Non puoi promettere cose che sai benissimo di non poter manetenere :ahah:
Mabo81
Re: Varie MorphOS
Messaggioda cip060 » ven apr 27, 2012 7:54 pm
Rilasciato aggiornamento per mplayer dal nostro caro amico FAB
http://fabportnawak.free.fr/mplayer/MPl ... .04.18.lha
Re: Varie MorphOS
Messaggioda divina » sab apr 28, 2012 2:23 am
MPlayer 1.0-SVN-r34869
26.04.2012
- Updated to 18.04.2012 svn (r34869)
- Removed a busy loop during cache filling phase.
- Fixed RTMP protocol.
- Don't crash when reading stdin when cache is enabled.
- GUI module:
- Added search function in playlist
- Show a dropdown indicator for the add file/dir/playlist/stream button.
Re: Varie MorphOS
Messaggioda divina » dom mag 27, 2012 10:11 pm
Re: Varie MorphOS
Messaggioda MacGyverPPC » ven giu 01, 2012 1:21 pm
Re: Varie MorphOS
Messaggioda divina » gio giu 21, 2012 12:30 am
Scriba 0.0.12 wordprocessor, FUSE e NTFS-3G R3 filesystem layer/framework, Mplayer 1.0 svn r34869 fixed, Odyssey Web Browser 1.17 browser ed aggiornamento rispettivi scripts e plugin, Hurrican 1.0.0.4 game, Python, PyMUI, PyCairo, Mercurial , Hollywood 5, Hollywood Designer 4.0 e plugins, MirrorCopy 2.2, Grunch 1.37 ...
Re: Varie MorphOS
Messaggioda divina » sab giu 23, 2012 11:05 pm
guida installazione MorphOS 3.0 da Obligement
http://obligement.free.fr/articles/morp ... lation.php
recesione, test MorphOS 3.0
http://jpv.wmhost.com/morphos/morphos3/
raggiunte 1473 registrazioni in data odierna
Re: Varie MorphOS
Messaggioda divina » lun giu 25, 2012 10:57 pm
thread nuovamente aggiornato, rilasciato Scriba 0.0.14 word processor
