Varie MorphOS
Re: Varie MorphOS
Messaggioda divina » ven set 30, 2011 2:47 pm
divina ha scritto:"GB3" Gribouillis3 beta
http://www.nonsoloamiga.com/forum/viewt ... t=128#p597
altre infos in merito a "GB3" Gribouillis3 beta
More information (current state):
- it's a paint program for artists .
- it's coded in MUI+Python (my PyMUI module) for UI and C for low-level drawing routines.
- it's designed for pressure sensitive devices, even if it works with a classical mouse, but pressure is fixed for this last.
- Not size-limited drawing surface.
- Non limited undo/redo.
- Non limited layers.
- Multiple documents.
- True RGB documents (working with internal 15bits pixels buffers).
- Loading in all formats supported by PIL (Python Imaging Library) as JPEG, PNG and OpenRaster (.ora).
- Saving in PNG and OpenRaster.
- Supported Palette file formats: .pal (internal) and .aco (Adobe Photoshop Color File Format).
- Fully customizable brushes with integrated manager.
- Line/Ellipse guide tools.
- Easy tools and color historic access as document overlay widgets.
- Independant layer transform matrix (rotation/translation supported).
- Per document view matrix (rotation/scale/translation).
- All inputs (keyboards, tablet tools) are fully customizable.
And note as it'll be a beta release, some features (more or less ready in code but finalisations needed, like viewport split, color management, CMYK documents, ...) missings but are planned for the 3.x serie.
The alpha version currently tested by two experimented graphists (big thanks to them!) is in frozen stage, before the beta packaging process.
I'm looking for tweak some parts and when I feel that GB3 is ready for public delivery... you know
Re: Varie MorphOS
Messaggioda cip060 » ven set 30, 2011 2:55 pm
Quando esce? :sbam:
Re: Varie MorphOS
Messaggioda Mabo81 » ven set 30, 2011 4:45 pm
cip060 ha scritto:Quando esce? :sbam:
Speriamo presto :ultralol: :ultralol: :ultralol:
Mabo81
Re: Varie MorphOS
Messaggioda MacGyverPPC » ven set 30, 2011 8:16 pm
Bello! O mi portano anche quello su OS4 o prima o poi tiro una martellata al Peg per vedere se si sveglia,se non trovo prima del denaro da spendere per ripararlo o prendermi un Mac per Mos. :ahah:
Re: Varie MorphOS
Messaggioda divina » gio ott 13, 2011 11:25 pm
thread aggiornato viewtopic.php?f=40&t=14653&p=171173#p171173
recensione del gioco Return to Castle Wolfenstein per MorphOS2.x/3.x da Obligement
http://obligement.free.fr/articles/retu ... nstein.php
MorphOS 3.0 sarà mostrato presso l' Amiwest 2011 in data 21, 22, 23 Ottobre, anche su notebook PowerBook G4 http://www.amiwest.net
presumibile rilascio a breve dell' applicativo Grunch dallo sviluppatore Guido Mersmann http://www.geit.de/eng_index.html
Re: Varie MorphOS
Messaggioda divina » mar ott 18, 2011 12:29 am
disponibile nuovo aggiornamento di MagicalInk 1.0 beta3 applicativo grafica vettoriale
MagicalInk-Update Bad-Bramstedt-2011-Version
The vector graphic editor MagicalInk written by Carsten Siegner has been updated which now can handle HTML-5 export as well as supports the hpdf.library. According to the author the programm is becoming a "Adobe Pagemaker" for MorphOS.
With MagicalInk it is now possible to create websites offline and then upload them with a corresponding FTP-client to the server.
MorphOS 3.0 sarà mostrato su notebook PowerBook G4 anche al Alchimie 2011 http://www.triplea.fr/alchimie/pages/index.php (11,12,13 Novembre), dallo sviluppatore Fabien Coeurjoly
Re: Varie MorphOS
Messaggioda divina » mar ott 18, 2011 8:34 pm
video Grunch e MagicBeacon in azione, mostrati al meeting Bad Bramstedt
http://www.youtube.com/watch?v=IKWVhkRw ... r_embedded
video di MagicalInk 1.0 beta3 in azione, mostrato al meeting Bad Bramstedt
http://www.youtube.com/watch?v=RW1TYeCi ... r_embedded
Re: Varie MorphOS
Messaggioda divina » gio ott 27, 2011 11:36 pm
thread aggiornato viewtopic.php?f=40&t=14653&p=171173#p171173 con nuova guida alla programmazione dallo sviluppatore @Krashan ed aggiornamenti di Grunch e WirelessDesktop
Re: Varie MorphOS
Messaggioda divina » ven nov 04, 2011 12:01 am
thread aggiornato viewtopic.php?f=40&t=14653&p=171173#p171173 con nuovi/aggiornati scripts per Odissey Web Browser 1.15, Grunch 1.25 ...
Re: Varie MorphOS
Messaggioda cip060 » sab nov 05, 2011 1:57 pm
Cosa e' successo a grunch??
ieri aggiornando alla 1.25 avevo notato le modifiche sulla barra dei file come nome titolo versione istallato o no aggiornamenti il posto dove era istallato ma ieri aggiornato alla 1.26 sono sparite e quando viene caricato ci mette 2 minuti per cricare la lista dei file!!! :sbam: :sbam:
qualcuno ha notato questo problema??
Re: Varie MorphOS
Messaggioda divina » dom nov 06, 2011 12:24 am
Grunch 1.26 è ok qui, fa il suo normale lavoro :)
Re: Varie MorphOS
Messaggioda samo79 » dom nov 06, 2011 12:39 am
Bene ora finalmente va anche su OS4 :felice:
Re: Varie MorphOS
Messaggioda MacGyverPPC » dom nov 06, 2011 12:10 pm
samo79 ha scritto:Bene ora finalmente va anche su OS4 :felice:
Scusa ma dov'è che lo posso scaricare? Son curioso di vederlo sul mio OS4 :riflette:
Re: Varie MorphOS
Messaggioda cip060 » dom nov 06, 2011 12:31 pm
divina ha scritto:Grunch 1.26 è ok qui, fa il suo normale lavoro :)
qua' ci mette una vita a caricare la lista del database al contrario della 1.25 e mancano tutte le informazioni che erano nelal versione 1.25 solo nome programma e se e' istallato o no e dove e' sulla 1.25 era scritto versione e altre informazioni :sbam:
Re: Varie MorphOS
Messaggioda Miky060 » dom nov 06, 2011 4:12 pm
Mi sa che ha ragione cip, qui ogni volta che lancio Grunch 1.26 scarica nuovamente le immagini delle applicazioni da mettere nel cassetto "database"..
Miky060
