Problema strano
Re: Problema strano
Messaggioda samo79 » mar ago 03, 2010 1:19 pm
Jambalah ha scritto:@Samo:
AAAAAHHHHHH! Pure plagiatore sei!!!! :ahah: Ben fatto!!
Mi sembra che la traduzione sia ok :ammicca:
Ma come plagiatore me l'hai passata te per e-mail :frusta:
:carucciiii:
Re: Problema strano
Messaggioda Fab1 » mar ago 03, 2010 2:29 pm
@cip060
Also make sure you downloaded WebCore fonts first (run "Download Fonts" icon in OWB directory). The default fonts aren't really suited for Web use, and WebCore fonts can't be installed by default for license reasons.
Regarding youtube, it was told earlier i believe, but make sure that:
- you click the html5 subscription link at http://www.youtube.com/html5
- you set user agent as safari in owb prefs->network (youtube have enforced a lame navigator check a couple days ago).
- you added the script Scripts/youtube_fullscreen_fix.js (needed because youtube also broke fullscreen mode two months ago...) through menu windows->scripts.
- you added the script youtube.js (the updated version at http://fabportnawak.free.fr/owb/scripts/ because youtube also broke that a week ago or so), to allow playing youtube videos that haven't been encoded to HTML5 yet. It will remove the Flash element and add the HTML5 video instead. But note that you should still have the flash plugin to avoid getting a "You don't have Flash" message that will abort the HTML5 playback at loading.
It's really annoying to need all this because youtube breaks stuff all the time.
Someone can translate if English doesn't make it. :)
Fab1
Amico
Re: Problema strano
Messaggioda Jambalah » mar ago 03, 2010 2:45 pm
erased
Ultima modifica di Jambalah il mar apr 26, 2011 8:55 am, modificato 1 volta in totale.
Jambalah
Re: Problema strano
Messaggioda cip060 » mar ago 03, 2010 2:50 pm
ecco appunto cominciamo a ragionare!!
scaricare i font e gli aggiornamenti da un'istallazione liscia come primo punto nessuno me lo aveva detto :boing:
e lo script aggiornato e i video da vedere su youtube sezione html 5!!
(ovviamente non tutti sono disponibili
ma la conversione non la fa' al volo?
Re: Problema strano
Messaggioda samo79 » mar ago 03, 2010 3:10 pm
Jambalah ha scritto:Si ricordo..! :scherza:
...ehm.... era una cosa detta così.. per fare teatro.. :boing:
:eheh:
Re: Problema strano
Messaggioda Jambalah » mar ago 03, 2010 3:19 pm
erased
Jambalah
Re: Problema strano
Messaggioda cip060 » mar ago 03, 2010 3:33 pm
e va be dai sono quasi a regime oramai
in ogni caso il discorso video html 5 e' risolto gli altri video li vedo con qualita bassa ma credo che il problema sia la ram video!!!
caricato graphic memory sulla barra mi indica con OWB aperto una media di 5 mega liberi!! non sono moltissimi ecco perche' ci vuole la versione 1.5 con 64 mega di ram!!
magari il prossimo aggiornamento ottimizzeranno l'uso della VRAM ma credo si possa fare poco
al massimo lo vedo in bassa il video e comunque per scaricarlo lo posso scaricare in alta e poi guardarlo con mplayer!
forse ho capito per risolvere in parte il problema (anche del tutto)
praticamente ero in 1280x1024 a 24 BIT su schermo da 17 CRT e questo credo sia un limite sia del monitor CRT che delal risoluzione a 24BIT e mi fuma tutta la VRAM!! probabilmente con un LCD serio il refresh video ne gioverebbe in ogni caso adesso ho messo 1280x1024 a 16 BIT pero e infatti come previsto mplayer e mp3 e OWB non scattano e Graphic Memory mi indica 13 mega di VRAM stbili
quindi dovrei aver risolto
Re: Problema strano
Messaggioda divina » mar ago 03, 2010 6:07 pm
cip060 ha scritto:ecco appunto era la dimensione minima che mi ha fregato :sbam: :sbam: bene risolto anche questo piccolo inghippo!!! :ultralol:
discorso vram ovviamente avendo la versione 1.42 ne ho 32 mega
e diventa spesso in rosso eventualmente e'292 mega libera e non 2.92!!
mo vedo
il punto è appunto questo :felice: con i Mac Mini G4 non con @1500 hai la scheda video con 32Mb vram, pertanto devi prestare molta attenzione in tal senso quando utilizzi più applicativi che incidono in tal senso ... ti consiglio inoltre nel tuo caso specifico di non andare oltre la risoluzione 1280x1024 (prova anche a vedere se a 16bit migliora rispetto a 24bit) e disabilita le funzionalità grafiche avanzate di MorphOS
Re: Problema strano
Messaggioda cip060 » mar ago 03, 2010 6:29 pm
infatti quello che ho scritto e' appunto questo
in ogni caso non posso anare oltre 1280x1024 monitor crt da 17 non me lo permette e'gia tanto questa risoluzione
in ogni caso se hai letto bene mettendo una risoluzione senpre 1280x1024 ma a 16 BIT ho guadagnato il doppio della VRAM!! e adesso sono apposto e non scatta e non si pianta piu'
fondamentalmente il problema era la profondita della risoluzione a 24 BIT che mi fregava tutta la RAM video!!
adesso resta sempre sui 15 mega di ram video in ogni caso che apra filmati mp3 in background e OWB resta sempre stabile non scende mai da la :happyboing:
Re: Problema strano
Messaggioda divina » mar ago 03, 2010 6:37 pm
cip060 ha scritto:infatti quello che ho scritto e' appunto questo
viewtopic.php?f=40&t=14323#p164894
02 ago 2010 21:57
<<- prova a vedere il consumo della VRAM ... vai in alto a destra, moduli ed attivi "Graphicsmemory" (logicamente troverai altro di utile sempre lì in moduli, già che ci sei ), e controlla se sei al limite con la VRAM quando usi questi programmi, tanto per iniziare ...>>
Re: Problema strano
Messaggioda cip060 » mar ago 03, 2010 6:45 pm
si si ho fatto tutto e'sempre attivo in alto sulla barra ripeto e' tutto stabile e funzionante adesso diciamo che resto come consumo di ram a meta se sono 32 mega sono sempre attorno ai 15 mega di avanzo 50% di uso della ram con risoluzione 1280x1024 a 16 BIT con la stessa risoluzione a 24 BIT ero a praticamente 95% ero alla fine :happyboing:
Re: Problema strano
Messaggioda divina » mar ago 03, 2010 6:48 pm
bravo :felice:
poi come ti dicevo disabilita le funzionalità grafiche avanzate di Ambient (e volendo anche 15bit potrebbero darti altro spunto in tal senso)
Re: Problema strano
Messaggioda cip060 » mer ago 04, 2010 12:17 am
no va bene cosi' adesso che e' stabile
