Varie MorphOS
Re: Varie MorphOS
Messaggioda divina » ven mag 20, 2011 11:54 pm
Re: Varie MorphOS
Messaggioda divina » mar mag 24, 2011 8:17 pm
ulteriori nuovi aggiornamenti del filesystem IceFileSystem 2.5 e di IceDoctor 1.0
viewtopic.php?f=40&t=14653&start=0
Write locking volume with zero key, could not be unlocked again, fixed.
A serious internal bug fixed.
action_end() improvement.
Silly optimisation prevented error requesters to work when FS was used on
boot partition. Now works again.
o Drives were inhibited when not really needed, fixed.
o Internal error requesters popping up with "recover lost extents" option enabled, fixed.
o Cosmetic changes.
o Recycledir scanning/repair improved.
o Improved handling of broken entry names.
o Quit while scanning didn't work, fixed.
o Forgotten flush of meta changes, oops.. fixed.
o "Resume from backup" didn't work, fixed.
Re: Varie MorphOS
Messaggioda divina » mer mag 25, 2011 1:04 am
qualcuno ha installato IceFileSystem 2.5 su un Apple Macintosh G4 (non Pegasos) in MorphOS2.x, nel hd di bootstrap, sfruttando mounter ? (non ho ancora avuto tempo per provarlo in tale modalità)
Re: Varie MorphOS
Messaggioda cip060 » lun mag 30, 2011 1:45 pm
Aggiornamento Da FAB scum vm 1.3.0
Download
http://fabportnawak.free.fr/scummvm/scummvm-1.3.0.lha
Sito di FAB
Re: Varie MorphOS
Messaggioda Kyle » lun mag 30, 2011 6:46 pm
Bella lì, meno male a Fab non interessavano i giochi :felice:
Re: Varie MorphOS
Messaggioda cip060 » lun mag 30, 2011 7:12 pm
Infatti!! lui fa i port degli emulatori!!
infatti uae gngeo scumm e altri :ride:
Re: Varie MorphOS
Messaggioda divina » gio giu 02, 2011 1:37 am
rilasciati Blender 2.57.1 r155M exe update fix testing , gioco Word Me Up XXL 1.3 , ScummVM 1.3.0
Re: Varie MorphOS
Messaggioda divina » lun giu 06, 2011 11:11 pm
rilasciato il mail client SimpleMail 0.37 (mail client con supporto IMAP)
http://meta-morphos.org/download.php?op=mydown&did=371
http://sourceforge.net/projects/simplemail
Re: Varie MorphOS
Messaggioda divina » gio giu 16, 2011 3:50 pm
ulteriore nuovo aggiornamento di IceFileSystem 2.6rc1
2.6 (2011-June-07)
Setting file comments broke in 2.5, fixed.
A potential notification issue fixed.
A potential issue with early requesters fixed.
rilasciati inoltre due games (ed aggiornamento) carini Hex-a-Hop 1.1.0 e The Legend of Edgar 0.85
http://hak.binaryriot.org/hex-a-hop-1.1.0-morphos.lha
http://hak.binaryriot.org/edgar-0.85-morphos.lha
Re: Varie MorphOS
Messaggioda divina » gio giu 16, 2011 3:51 pm
Re: Varie MorphOS
Messaggioda cip060 » ven giu 17, 2011 11:00 am
divina ascolta oggi vorrei provare ice filesystem!!
mi basta copiare i file del pacchetto nelle varie cartelle giusto?
ma nella root base o dentro alla cartella MOS?
e basta vero al riavvio e'disponibile?
ovviamente dopo devo usare il programma incluso per poter formattare i ICE FS giusto?
poi ho letto della key da 21 euro! :mah:
mi pare di aver capito che il filesystem se non lo registro funziona pefettamennte ma ogni volta che lo uso rallenta sempre di piu'
ho capito bene ? tu che lo hai provato come va'?vale la pensa registrarlo? o meglio un disco firewire? o usb nel caso?
fammi capire bene
Re: Varie MorphOS
Messaggioda divina » sab giu 18, 2011 12:06 am
@cip060
lo utilizzo non in modalità "produttiva" :felice: (gli ho dedicato una unità dedicata) ; potresti dedicargli una unità esterna USB2.0.
Sì vanno collocati nelle directories nel path "/".
Una utile guida per l' utilizzo di IceFileSystem http://obligement.free.fr/articles/icefilesystem24.php
Mi trovo benissimo con SFS in MorphOS2.7, mai avuto alcun problema con questo filesystem e penso proverò PFS3 portato in modo nativo da Harry Sintonen (alias @Piru) presumibilmente nella prossima versione MorphOS2.8
Re: Varie MorphOS
Messaggioda cip060 » sab giu 18, 2011 10:08 am
Il discorso della KEY?
Re: Varie MorphOS
Messaggioda Jambalah » lun giu 20, 2011 9:58 am
Aggiornamento di Snapshoter che arriva alla versione 1.5.1.
Tra i vari bugfix e aggiunte sono state introdotte queste novità:
- la possibilità di una video capture, di qualsiasi dimensione si desideri, con salvataggio del filmato in formato AVI
- un nuovo engine per il composer, che permette di utilizzare i propri font e di editarne lo style (grassetto, sottolineato, corsivo, ombra...)
- auto aggiornamento del programma via dropbox per permettere la condivisione della clipboard e delle foto tra diverse periferiche
- palette RGB migliorata
Il programma è scaricabile qui:
http://www.xabierpayet.com/
Questo programma si evolve sempre di più. E in maniera deliziosa!
Jambalah
Re: Varie MorphOS
Messaggioda samo79 » lun giu 20, 2011 4:49 pm
Concordo, SnapShoter è davvero molto molto carino :felice:
