Mistery Device?
Messaggioda ikir » gio mar 23, 2006 9:55 am
Decisamente interessante
Features
* 533 to 667MHz, 1,334 DMIPS @ 667MHz
* 32K-I/32K-D L1 caches, and 256K L2/SRAM with parity protection
* 32/64-bit DDR I/DDR II SDRAM Controller, for DDR166/333 and DDR333/667 operation
* Three PCI Express Interfaces, one with eight lanes configurable as x8, x4, x1 and two with four 4 lanes configurable as x4, x1; 2.5 Gbps full duplex per lane; Compliant with PCI Express base specification 1.0a; configurable as root or end point
* 64-bit PCI-X version 2.0 3.3v interface, up to 133MHz / DDR266; 1.6GBps sustained bandwidth, 2.13GBps peak bandwidth; Support for PCI-X v1.0a up to 133MHz and PCI v2.3, up to 66MHz
* Opaque PCI Epress to PCI Express, and PCI Express to PCI-X bridge functionality
* Ability to boot from the primary PCI-X bus memory
* XOR core accelerates parity generation and check functions
* Intelligent Messaging Unit (I2O specification)
* Two-channel DMA included with I2O, One-channel DMA included with XOR
* External Bus Control (EBC) Interface (up to 83MHz) supporting up to three ROM, RAM, or EPROM peripheral devices
* One 10/100/1000 Mbps Ethernet MAC, full duplex GMII/MII interface with DMA capability via Memory Access Layer (MAL)
* Three serial ports (16750 compliant UARTs) with 64 byte FIFOs
* Two IIC controllers
* Up to 32 General Purpose I/Os (GPIO)
* General purpose timers
* Universal Programmable Interrupt Controller supports 16 external interrupt sources and 101 internal sources
* JTAG, RISCTrace? and RISCWatch? support
m3x sei troppo lamer :felice:
Messaggioda m3x » gio mar 23, 2006 10:32 am
La famiglia di processori è quella giusta, però i due modelli che hai indicato nei link non hanno la FPU (ed hanno un costo ancora abbastanza alto...) :eheh:
Messaggioda yashin71 » gio mar 23, 2006 11:22 am
E' ipotetico oppure amigaos4 funziona già su queste schede?
yashin71
Messaggioda MazinKaesar » gio mar 23, 2006 11:37 am
yashin71 ha scritto:E' ipotetico oppure amigaos4 funziona già su queste schede?
Me lo chiedo anche io....
Messaggioda NubeCheCorre » gio mar 23, 2006 11:38 am
@All
Conoscete il film " LA RETATA " ?.. e' un bel film.. potremmo proporne una versione live in casa di Max.. :ride:
Messaggioda Lecta » gio mar 23, 2006 12:06 pm
NubeCheCorre ha scritto:@All
Dubito che trovereste qualcosa di compromettente, dovreste trovare anche l'ingresso alla MaxCaverna(TM)...
:ride:
Stefano Guidetti
AmigaOS 4 Translator & Betatester
Qualunquemente...
Lecta
Messaggioda m3x » gio mar 23, 2006 1:07 pm
Non posso rispondere più di un sibillino NI :eheh2:
Messaggioda Lecta » gio mar 23, 2006 2:12 pm
Ho pensato di mettermi a vendere carote... i bastoni sono convinto che arriveranno numerosi dagli utenti del forum... :ahah: :ahah:
Stefano Guidetti
Qualunquemente...
Lecta
Messaggioda MazinKaesar » gio mar 23, 2006 2:59 pm
Quanti te ne servono? Io ne ho una buona scorta...
"NI"... è un no ipocrita! Vergogna! :scherza:
Messaggioda NubeCheCorre » gio mar 23, 2006 3:11 pm
@Max
Assumiti il peso delle tue responsabilita' e di SI ! :ride:
Messaggioda Zender » gio mar 23, 2006 3:28 pm
Allora diciamo... come gira AOS4 su queste macchine ?
:scherza:
Zender
Messaggioda yashin71 » gio mar 23, 2006 3:31 pm
:scherza:
e se gira chi ha pagato la licenza? :ahah: :ahah: :ahah: :ahah: :ahah:
yashin71
Messaggioda clros » gio mar 23, 2006 3:35 pm
Uhmmm... :riflette:
Nella foto di m3x, si vede solo l'HW, non si vede "girare" alcunchè...
E' sicuramente qualcosa in più rispetto a Troika o PowerVixxen (li non c'è nemmeno l'HW), ma aspetterei a parlare, anche se la serietà di m3x e' stata sempre fuori da ogni dubbio...
Messaggioda peterray » gio mar 23, 2006 3:35 pm
Allora dovrebbe essere questo direi (è l'unico con FPU da quanto ho trovato):
https://www.amcc.com/MyAMCC/jsp/public/ ... D=PPC440EP
Ciao
Gabriele
peterray
Messaggioda m3x » gio mar 23, 2006 4:28 pm
peterray ha scritto:Allora dovrebbe essere questo direi (è l'unico con FPU da quanto ho trovato):
Ciao
Gabriele
Infatti, la scheda in questione è la reference board per il 440EP, chiamata Yosemite :annu:
