Amigacoin
Re: Amigacoin
Messaggioda dipsomania » gio feb 27, 2014 12:25 am
Oh, yes, first time the Boing splash is showed on screen for a lot of seconds, 'cause about verifying of local db files. After it should show a window like my screenshot. I have no idea and I'm afraid about big/little endian stuff.
zzd10h ha scritto:@dispomania
I compiled your AmigaCoin under UbuntuPPC (it takes ages even on dual cores...) but when started I only have the Boing splash screen for few seconds and nothing more after. No window, no process active. Nothing...
See screenshot :
http://zzd10h.amiga-ng.org/Divers/Amiga ... ntuPPC.png
Is it normal ? Certainly that I missed something.
To be honest, I never use a bitcoin client.
I even quick read Dogecoin quick-start guide but I understood nothing . :riflette:
It could be useful if you add a "how to for total newbie" on your webpage ?
Tra il Sacro...
_ Amiga 1200, Hardital TQM 68030/68882 50 MHz, 8 MB Fast Ram, HD 85 MB, AmigaOS 3.0, C1940
... e il profano...
_ AMD FX-6300 4.4 GHz, 8 GB Ram, Radeon 7870 Tahiti LE 2 GB VRam, HD 1 TB, Ubuntu Studio 14.04, AROS Icaros Desktop 2.0.3
_ Acer Extensa 5220, Intel Core 2 Duo 2.2 GHz, 2 GB RAM, HD 750 GB, Lubuntu 14.04
dipsomania
Amico
Re: Amigacoin
Messaggioda zzd10h » gio feb 27, 2014 12:37 am
And where are located these "local db files" ?
Are they created by AmigaCoin or another program that I have to start before ?
zzd10h
Re: Amigacoin
Messaggioda dipsomania » gio feb 27, 2014 12:45 am
They're created by my application in /home/youruser/.amigacoin and there should be a debug log.
zzd10h ha scritto:And where are located these "local db files" ?
Tra il Sacro...
... e il profano...
dipsomania
Amico
Re: Amigacoin
Messaggioda zzd10h » gio feb 27, 2014 8:45 am
.amigacoin/db.log is empty
Only one log file filled is
zzd10h@X1000:~/.amigacoin/blocks/index$ cat LOG
2014/02/26-22:48:49.487111 f7dba00000000000 Recovering log #15
2014/02/26-22:48:49.487258 f7dba00000000000 Level-0 table #18: started
2014/02/26-22:48:49.539269 f7dba00000000000 Level-0 table #18: 183 bytes OK
2014/02/26-22:48:49.600244 f7dba00000000000 Delete type=0 #15
2014/02/26-22:48:49.600333 f7dba00000000000 Delete type=2 #8
2014/02/26-22:48:49.600394 f7dba00000000000 Delete type=2 #11
2014/02/26-22:48:49.600453 f7dba00000000000 Delete type=2 #5
2014/02/26-22:48:49.600511 f7dba00000000000 Delete type=2 #14
2014/02/26-22:48:49.600568 f7dba00000000000 Delete type=3 #13
zzd10h
Re: Amigacoin
Messaggioda dipsomania » gio feb 27, 2014 10:40 am
Try to type "amigacoin-qt -DEBUGLOG" and one another debug log (more useful) will be created.
Tra il Sacro...
... e il profano...
dipsomania
Amico
Re: Amigacoin
Messaggioda ikir » gio feb 27, 2014 1:30 pm
Se ne sente parlare spessori BitCoin ultimamente.
OK ammettiamo che Hyperion paghi in BitCoin/AmigaCoin invece che NON PAGARE AFFATTO. Amikit perché dovrebbe accettare questa moneta? I suoi fornitori li paga con valuta diversa e accettata ovunque.
Re: Amigacoin
Messaggioda zzd10h » gio feb 27, 2014 7:18 pm
@dipsomania
No new debug file but more trace in the shell
zzd10h@X1000:~/amigacoin-master$ ./amigacoin-qt -DEBUGLOG
amigacoin-qt: src/main.cpp :2821 : bool InitBlockIndex(): l'assertion « block.hashMerkleRoot == uint256("0x7030aeccb3f27dac9c39a5e2fe4abca897ac62b2b428d3bcc7218904ca0a08f1") » a échoué.
Abandon (core dumped)
zzd10h
Re: Amigacoin
Messaggioda dipsomania » gio feb 27, 2014 11:22 pm
Beh, che dire, e' un tramite con cui scambiarsi servizi, piu' o meno come lo SCEC per fare un esempio, poi se qualcuno li vuole convertire in dollari, euro, sterline, puo' farlo usando uno dei tanti siti che permettono questo tipo di operazioni. Purtroppo la maggior parte della gente pensa soltanto a questi Bitcoin come qualcosa con cui specularci e fare profitto, con tutto' cio' che ne consegue (tipo la volatilita' del prezzo, anche se in questi ultimi mesi, nonostante la chiusura di uno dei piu' grandi siti di scambi - MtGox - a causa di un grosso furto che si era protratto da un paio di anni, ed altri casini e' rimasto stabile sui 500-600 dollari). Secondo me ha molto piu' senso se queste "monete" sono piu' legate alle comunita' o comunque a delle cose tangibili, in modo da essere molto meno virtuali. E' ancora presto per comprarsi cibo, una casa o un Amiga X1000 con queste robe qui, ma in futuro *potrebbe* accadere, difficile dirlo ora. Invece, tra utenti - programmatori, grafici, traduttori, semplici possessori amighisti - sarebbe ottimo, visto che i soldi non ci sono (e non ci saranno mai, bisogna ammetterlo!). Con le soluzioni convenzionali, dalla fine della Commodore, abbiamo ottenuto soltanto un pugno di mosche, basta vedere quanta gente c'era al primo Pianeta Amiga e quanta all'ultimo; continuando cosi' tra qualche anno Amiga morira' davvero, con solo qualche vecchio rimbambito che si scambiera' i 68030 a peso d'oro... :ammicca: :triste: Forse e' il momento di ragionare diversamente, per cercare di dare una vera svolta alla nostra piattaforma.
ikir ha scritto:Se ne sente parlare spessori BitCoin ultimamente.
Tra il Sacro...
... e il profano...
dipsomania
Amico
Re: Amigacoin
Messaggioda dipsomania » gio feb 27, 2014 11:58 pm
May it be occured by this -> http://bitcoin.stackexchange.com/questi ... n-notation ?
To be honest I never see PowerPC versions of these clients.
Can you try to build this -> https://github.com/litecoin-project/litecoin ? I got it from that project.
Thank you!
zzd10h ha scritto:@dipsomania
Tra il Sacro...
... e il profano...
dipsomania
Amico
Re: Amigacoin
Messaggioda zzd10h » sab mar 01, 2014 12:36 pm
Litecoin does the same.
2014-03-01 10:34:48 Litecoin version v0.8.6.2-g85f303d-beta ()
2014-03-01 10:34:48 Using OpenSSL version OpenSSL 1.0.1 14 Mar 2012
2014-03-01 10:34:48 Default data directory /home/zzd10h/.litecoin
2014-03-01 10:34:48 Using data directory /home/zzd10h/.litecoin
2014-03-01 10:34:48 Using at most 125 connections (1024 file descriptors available)
2014-03-01 10:34:48 Using 2 threads for script verification
2014-03-01 10:34:48 init message: Vérification du porte-monnaie...
2014-03-01 10:34:48 dbenv.open LogDir=/home/zzd10h/.litecoin/database ErrorFile=/home/zzd10h/.litecoin/db.log
2014-03-01 10:34:48 Bound to [::]:9333
2014-03-01 10:34:48 Bound to 0.0.0.0:9333
2014-03-01 10:34:48 init message: Chargement de l’index des blocs…
2014-03-01 10:34:48 Opening LevelDB in /home/zzd10h/.litecoin/blocks/index
2014-03-01 10:34:48 Opened LevelDB successfully
2014-03-01 10:34:48 Opening LevelDB in /home/zzd10h/.litecoin/chainstate
2014-03-01 10:34:48 LoadBlockIndexDB(): last block file = 0
2014-03-01 10:34:48 LoadBlockIndexDB(): transaction index disabled
2014-03-01 10:34:48 Initializing databases...
2014-03-01 10:34:48 32bd06294f8082fd40d4746207e0d4a98df76c598f935137f522cda0d53a049e
2014-03-01 10:34:48 12a765e31ffd4059bada1e25190f6e98c99d9714d334efa41a195a7e7e04bfe2
2014-03-01 10:34:48 b7a313ba5be66daf057448001cceda5de21237fcee752ef943a0cc7e439dde9d
zzd10h
Re: Amigacoin
Messaggioda cip060 » sab mar 01, 2014 12:44 pm
But Hiperion Accept Payments in amigacoin? :ride: :ride:
Who knows what he pulls out a payment amigacoin! :ride: :ride:
Re: Amigacoin
Messaggioda dipsomania » sab mar 01, 2014 5:54 pm
I read this https://github.com/litecoin-project/lit ... ild-osx.md , look Notes. :triste:
I think it needs to rewrite completely many parts and I don't have any PPC machine to do it at the moment.
Anyway if you have a pc x86, I can give you some coins. :-)
zzd10h ha scritto:Litecoin does the same.
Tra il Sacro...
... e il profano...
dipsomania
Amico
Re: Amigacoin
Messaggioda zzd10h » sab mar 01, 2014 6:40 pm
Thank you but I use really exclusively my X1000 :happyboing:
zzd10h
Re: Amigacoin
Messaggioda dipsomania » sab mar 01, 2014 6:44 pm
Ok! :ride:
zzd10h ha scritto:Thank you but I use really exclusively my X1000 :happyboing:
Tra il Sacro...
... e il profano...
dipsomania
Amico
Re: Amigacoin
Messaggioda dipsomania » mar mar 04, 2014 11:05 pm
Ciao, c'e' qualche grafico qui che potrebbe rifare i loghi e la grafica in generale? Quella fatta da me fa abbastanza schifo e non e' molto professionale. :ammicca:
Tra il Sacro...
... e il profano...
dipsomania
Amico
