WinUAE v4.3.0 Beta 6/7/8
Messaggioda AMIGASYSTEM » ven dic 06, 2019 1:08 pm
Aggiornammento v4.3.0 Beta 6
WinUAE v4.3.0 Beta 6: Download
WinUAE v4.3.0 64Bit Beta 6: Download
Novità versione Beta 6
- DMA debugger SPRxPOS/SPRxCTL and SPRxDATA/SPRxDATB was swapped.
- Lagless vsync: use raster line polling if Windows 7. D3DKMTWaitForVerticalBlankEvent() (still) seems to work badly in Windoes 7 (b5).
- PCMCIA overrode any Z2 boards at 0x600000-0x9fffff range. Any Z2 board conflict will now disable PCMCIA. (This is not really what happens in real world but you can't easily have multiple Z2 boards in A600 or A1200 either in real world. It can get confusing if you change Z2 boards and suddenly one or both boards simply stop working.)
- Added limits to internal horizontal bitplane rendering, in some situations (high AGA fetch mode, high resolution and/or subpixel mode) it overflowed to next line.
- Added support for AccessX 2000 IDE controller. Same ROM contents, different ROM address/data line "scrambling" than used in 500 variant.
- 68010 CLR.B <odd ea> caused address error. (CPU tester previous beta updates missed size check..)
- CPU tester updates, more bus error and address error special cases (branch instruction jumping to bus error address - 2 etc) checked and correctly emulated. Trace is also now much better supported.
Re: WinUAE v4.3.0 Beta 7
Messaggioda AMIGASYSTEM » dom dic 08, 2019 12:19 am
Aggiornammento v4.3.0 Beta 7: A distanza di qualche giorno una nuova beta che fixa e migliora l'emulazione, questa dovrebbe essere l'utima Beta, imminente l'uscita della versione v4.3. Stable.
WinUAE v4.3.0 Beta 7: Download
WinUAE v4.3.0 64Bit Beta 7: Download
Novità di questa versione
- Output DMA debugger output to log file with "vl" command.
- Fixed b6 horizontal bitplane buffer size check. (for example superhires wasn't fully visible)
Re: WinUAE v4.3.0 Beta 8
Messaggioda AMIGASYSTEM » mar dic 10, 2019 1:55 am
Ancora una nuova beta a distanza di qualche giorno che fixa e migliora l'emulazione, forse questa dovrebbe essere l'utima Beta, e per la prossima settimana l'uscita ufficiale della versione v4.3. Stable
WinUAE v4.3.0 Beta 8: Download
WinUAE v4.3.0 64Bit Beta 8: Download
Queste le novità:
- Partition HDF default geometry calculation changed if partition size is 1000M or larger, keeps total cylinders under 32768 = better compatibility with pre-OS3.9(BB2?) versions. Only changed when HDF is added using GUI. Config file loaded geometry won't change.
- RDB mode didn't disable if RDB HDF was selected and then switched to partition HDF using GUI.
- CD32 didn't boot from CD after reset (b1)
- DMA debugger update in b7 had incorrect commmand parsing.
- Microbotics HardFrame v1.9 ROM CRCs added.
- D3D11 HDR mode is not anymore enabled automatically (if compatible hardware is detected), it is now only enabled if gfx_hdr=true is in config file. This is experimental feature and should not be the default in official versions.
- RTG mode D3D9/11 overlay graphics support. (Scaling/positioning needs to be better but it needs more updates, after 4.3.0 is out)
