WinFellow v0.5.8
WinFellow v0.5.8
Messaggioda AMIGASYSTEM » mar lug 16, 2019 2:01 am
WinFellow Nuova versione dello storico Emulatore Amiga per Windows.
WinFellow v0.5.8: Download
New features:
- Support for RDB hardfiles was implemented; while creating a new hardfile from the WinFellow GUI still creates “plain” hardfiles, a Rigid Disk Block can be created using tools like HD Toolbox the default naming scheme for filesystem devices has been changed from DHx: to FSx: to avoid naming conflicts with existing RDB hardfiles
- A 64 bit build is now provided; the NSIS installer will install either the 32 or 64 bit version depending on the operating system that is used
Bug fixes:
- Improved handling of hardware interrupts and blitter delays; fixes freezes that could occur during installation of Workbench in earlier 0.5.x versions
- Fix wrong selection of render function after return from menu when application did not write to bplcon0 every frame; fixes garbled graphics in a Legend cracktro when returning from menu
- CLR reads before write; fixes loading of Outrun and a fast-mem test in Last Ninja 2
- Improve delay caused by logging in screen-mode enumeration (could amount to many seconds with multiple screens)
- Running in an environment with very slow graphics framerate, like a VM, could cause a deadlock; set wait time after event reset to avoid race condition
- Fix an issue where screenshots would occasionally not be taken in Direct3D graphics mode; this may also have impacted the ability to use Amiga Forever’s clipping editor
- Fix an issue where applying a new model preset would leave multiple blitter radio buttons selected
Maintenance updates:
- Project files were updated to Visual Studio 2019 using the toolset v141_xp
- The February 2010 DirectX SDK dependency was eliminated
- IPF Access API files were updated to the latest version, and support for it was enabled in 64 bit builds
