Roadie v1.3
Roadie v1.3
Messaggioda AMIGASYSTEM » mar giu 25, 2019 11:21 pm
Roadie: GUI per Roadshow che include alcuni strumenti di controllo e verifica dello Stack TCP/IP su Amiga
Roadie v1.3: Download
Run Commands:
- Go Online (if you're not already)
- Go Offline (if you're not already)
- Show Net Status (an overview of current Local IP|Gateway|DNS)
- Get Net Status (information on your current networking with Roadshow)
- Ping a given IP/Host (by default uses Googles main DNS server)
Edit Configuration files (Please see notice below!):
- Interface files
- Nameservers (DNS)
- Default Gateway (routing)
Also you can:
- Quit (run away!)
ARexx Commands (Default port is ROADIE)
- ONLINE [ Go Online ]
- OFFLINE [ Go Offline ]
- SHOW [ Show the main Roadie interface ]
The Icon has four optional tooltypes:
- CX_POPUP=YES|NO [ Defaults to YES if not set ]
- CX_POPKEY=ctrl lcommand help [ this can be changed by the user ]
- AREXXPORT=ROADIE [ this can be changed by the user ]
- AUTOCONNECT=YES|NO
Re: Roadie v1.3
Messaggioda savior » mer giu 26, 2019 3:35 pm
un'ottimo lavoro senz'altro, ma configurare roadshow è di una facilità estrema basta sapere l'indirizzo ip del tuo computer e del router.
savior
