Polybios PDF v1.1 OS3/OS4/MOS/AROS
Messaggioda AMIGASYSTEM » lun giu 24, 2019 9:23 am
Polybios:: Plug-In utilizzato per creare e visualizzare documenti PDF attraverso applicazioni create con Hollywood
HWP Polybios PDF v1.1: Download
Features:
- over 200 functions for creating and viewing PDF documents
- support for all graphics primitives
- full Unicode support
- fonts can be embedded inside PDF documents
- images and Hollywood brushes can be embedded inside PDF documents
- password-protected PDFs can be opened and created
- support for PDF encryption and compression
- files can be attached to PDF documents
- annotations can be added to PDF documents
- support for RGB, CMYK and gray color spaces
- transition effects can be embedded inside PDF documents
- hypertext links can be embedded inside PDF documents
- table of contents generation is supported
- inbuilt PDF viewer is based on the famous fast and powerful PDF engine used in a very popular browser by a very well-known American Internet company and is thus very compatible and complete
- PDF pages can be exported as Hollywood brushes
- PDF pages can be accessed as vector brushes allowing for lossless scaling, rotation, and transformation
- Polybios comes with over 150 pages of documentation to get you started quickly
- over 25 ready-to-run examples are included in the Polybios distribution
