WHDLoad v18.3 Released
Messaggioda AMIGASYSTEM » ven apr 07, 2017 2:36 pm
WHDLoad 18.3: Nuova versione del famoso installatore Giochi AMiGA, anche queasta versione non necessita della chiave di registrazione.
WHDLoad 18.3: Download
Queste le novità:
- chg: don't check for read-only-filesystem if option SavePath is used (issue #3355)
- fix: if option SavePath is used and the save path is not yet created WHDLoad will no longer try to delete files in the normal data directories if resload_DeleteFile is called
- fix: resload_SaveFileOffset now correctly works on files which are not preloaded and not yet present in the SavePath, in older releases dos error #203 was reported (issue #3355)
- chg: the behavior of the option CACHE in kickemu (sources/whdload/kick*.s) has been changed, previously it set the chip memory non cacheable (NC) now it sets it cacheable write-through (WT), recompiling Slaves using this option will change this for the resulting Slaves, for machines with cpu caches and no MMU otherwise no caches are enabled at all by WHDLoad
- chg: splash window corrected for non standard window borders (Mikhail Malyshev)
- fix: resload_DeleteFile reworked, no longer supports deleting directories, delete operation is cached if file was preloaded, now correctly works together with SavePath/K option
- chg: checking for a read-only filesystem is performed after executing a possible ExecuteStartup now (Stephane Julien)
- chg: kickemu now uses the host system bplcon0 to init gb_bplcon0, this should preserve genlock/lace setup (issue #2858), WHDLoad itself also use gb_bplcon0 for the initial custom setup
- fix: the interrupt redirect feature of ACA now correctly works with programs depending on the supervisor bit in the interrupt stack frame, this should fix problems with install using the kickstart emulation (Toni Wilen)
- chg: on 68060 the store/load bypass is no longer disabled if the cpu revision is >= 5
- new: support for Vampire/Apollo added, will be detected as 68040 now (older WHDLoad detected a 68020 because the presence of MSP and CAAR registers), MMU is always disabled
- fix: kickemu now correctly enables the fpu via resload_SetCPU if NEEDFPU is set
