RunInUAE PPC (PPC JIT v1.0.0)
Messaggioda MacGyverPPC » dom mag 03, 2015 11:14 pm
RunInUAE r8 beta 4 (PPC JIT v1.0.0)
Sorry it's taken so long folks, but you can now download/install RunInUAE beta which contains v1.0.0 of Almos Rajnai's PPC JIT for E-UAE:
Download RunInUAE_r8-beta4.lha
The other main changes from the earlier RunInUAE betas:
* WHDLoad updated to v18.1 (2015).
* The "Disk not present" requester no-longer appears when starting the CD32 emulation without a CD inserted.
* The screen titlebar now shows RunInUAE's version.
A reminder of the previous main changes seen in earlier RunInUAE betas:
* Support for JIT has been added. (Also added status LEDs.)
* Support for a second joystick.
* Much better recognition of multiple ADF disks.
* Harddisk-installed games should save your progress (if this is supported).
* Drastically simplified the format of the per-game config files.
* Fixed some bugs, including a nasty one which would destroy the ".uaerc_RunInUAE" file.
If no-one notices any big problems with this beta, then I shall release it via AmiUpdate...
http://www.amigans.net/modules/xforum/v ... 35&forum=8
