La lista degli Update da dopo l'uscita di Os 4.1.6
Messaggioda tlosm » mar ott 01, 2013 1:28 pm
Ecco a voi cosa è variato da dopo 4.1.6
3DLabsPermedia_chip SYS:Kickstart/3DLabsPermedia2.chip 7.32 2012-02-19
AddBuffers sys:c/addbuffers 53.1 2013-07-21
AmiDock sys:utilities/commodities/amidock 53.35 2010-12-29
AsyncWB SYS:Utilities/Commodities/AsyncWB 53.14 2013-03-02
ATIRadeon_chip SYS:Kickstart/ATIRadeon.chip 53.26 2012-11-26
Calculator_cmd SYS:Utilities/Calculator 53.16 2012-09-12
camd_lib SYS:Libs/camd.library 53.6 2013-04-09
ClickToFront SYS:Utilities/Commodities/ClickToFront 53.10 2013-02-17
dos_lib SYS:Kickstart/dos.library.kmod 53.126 2013-02-23
elf_lib SYS:Kickstart/elf.library.kmod 53.19 2013-03-27
Emulation SYS:Emulation/AmigaVersion.txt 53.1 2013-01-19
emulation_lib SYS:Libs/Picasso96/emulation.library 53.1 2012-04-14
envy24ht_audio SYS:Devs/AHI/envy24ht.audio 5.17 2013-05-02
Find SYS:System/Find 53.13 2012-11-24
gadtools_lib SYS:Kickstart/gadtools.library.kmod 53.6 2013-06-17
graphics_lib SYS:Kickstart/graphics.library.kmod 53.6 2012-06-01
hdaudio_audio SYS:Devs/AHI/hdaudio.audio 6.20 2013-07-23
intuition_lib SYS:Kickstart/intuition.library.kmod 53.42 2013-01-07
IPrefs SYS:C/IPrefs 53.21 2012-11-19
Kernel SYS:Kickstart/kernel 53.39 2012-12-13
List sys:c/list 53.7 2013-09-03
locale_lib SYS:Libs/locale.library 53.6 2013-05-05
MD5Sum sys:c/md5sum 53.3 2013-08-20
MUI SYS:MUI/Libs/muimaster.library 20.2351 2013-06-10
Notifications SYS:Prefs/Notifications 53.26 2013-03-30
PCIGraphics_card SYS:Kickstart/PCIGraphics.card 53.5 2012-09-08
PCI_CatweaselJoystick_driver SYS:Libs/AmigaInput/PCI_CatweaselJoystick.driver 53.2 2012-04-18
Picasso96API_lib SYS:Libs/Picasso96API.library 53.4 2012-04-14
PrefsObjectsEditor SYS:Utilities/PrefsObjectsEditor 53.4 2013-02-11
Prefs_GUI SYS:Prefs/GUI 53.8 2012-05-06
Prefs_Input SYS:Prefs/Input 53.4 2012-06-30
Prefs_WBStartup SYS:Prefs/WBStartup 53.24 2012-02-12
prefs_workbench SYS:Prefs/Workbench 53.10 2011-08-10
pthreads_lib SYS:Libs/pthreads.library 53.9 2012-06-09
realtime_lib SYS:Libs/realtime.library 53.5 2012-10-27
rexxsyslib_lib SYS:Libs/rexxsyslib.library 53.4 2013-02-21
rtg_lib SYS:Kickstart/rtg.library 53.30 2012-11-21
RunInUAE APPDIR:RunInUAE 1.7 2013-01-10
Shell SYS:Kickstart/shell.kmod 53.12 2012-07-07
SiliconMotion502_chip SYS:Kickstart/siliconmotion502.chip 53.10 2013-03-27
speedbar_gc SYS:Classes/Gadgets/speedbar.gadget 53.12 2013-07-04
timesync_lib SYS:Libs/timesync.library 53.7 2013-04-30
W3D_Permedia2_lib SYS:Libs/Warp3D/HWDrivers/W3D_Permedia2.library 52.45 2012-08-28
W3D_Picasso96_lib SYS:Libs/Warp3D/GFXdrivers/W3D_Picasso96.library 53.10 2013-02-07
W3D_R200_lib SYS:Libs/Warp3D/HWDrivers/W3D_R200.library 53.21 2012-09-03
W3D_Radeon_lib Sys:libs/Warp3D/HWDrivers/W3D_Radeon.library 53.19 2012-08-27
Warp3D_lib SYS:Libs/Warp3D.library 53.18 2012-08-28
wbstartup_lib SYS:Libs/wbstartup.library 53.8 2013-09-26
window_class SYS:Classes/window.class 53.50 2013-01-08
WorkbenchGuide SYS:Locale/Help/english/Sys/Workbench.guide 53.5 2012-12-18
workbench_lib SYS:Libs/workbench.library 53.51 2012-12-08
There are 51 entries in the list.
Re: La lista degli Update da dopo l'uscita di Os 4.1.6
Messaggioda NubeCheCorre » mar ott 01, 2013 6:32 pm
wow! :felice:
non male, bene così :felice:
Messaggioda samo79 » mar ott 01, 2013 7:10 pm
Si non male, oggi altri piccoli 4 update :felice:
Messaggioda tlosm » mar ott 01, 2013 7:25 pm
si dovrebbero essere già in lista
Messaggioda ikir » mer ott 02, 2013 2:42 pm
Bene bene... ma ci vorrebbe un nuovo update succoso, già solo per la comodità di avere già tutto aggiornato.
Messaggioda tlosm » mer ott 02, 2013 7:42 pm
5 NUOVI UPDATE IN MENO DI 2 GIORNI!
Public updates released since AmigaOS 4.1 Update 6
Note: Latest versions only.
Archive Path Version Date
ASL_Library sys:libs/asl.library 53.49 2013-09-17
intuition_lib SYS:Kickstart/intuition.library.kmod 53.43 2013-07-17
ListBrowser_GadgetClass sys:classes/gadgets/listbrowser.gadget 53.61 2013-08-08
LogViewer SYS:Utilities/LogViewer 53.8 2013-07-17
Slider_GadgetClass sys:classes/gadgets/slider.gadget 53.13 2013-09-11
TimeZone_Library sys:libs/timezone.library 53.8 2013-07-26
There are 56 entries in the list.
Messaggioda samo79 » gio ott 03, 2013 9:23 am
Ecco la lista completa ufficiale !
http://update.amigaos.net/
Messaggioda NubeCheCorre » gio ott 03, 2013 11:28 am
potevano farla meglio, quella pagina, esteticamente parlando... le tabelle!! argh!!!
Messaggioda Amy-Mor » gio ott 03, 2013 12:19 pm
Ragazzi ma ci sarebbe modo di averli in un unico pacchetto cumulativo?Non posso aggiornare poichè non ho l'AmigaOne500 collegata ad internet e quindi non uso l'AmiUpdate :kaput:
Help me!
Amy-Mor
Messaggioda tlosm » gio ott 03, 2013 1:12 pm
Amy-Mor ha scritto:Ragazzi ma ci sarebbe modo di averli in un unico pacchetto cumulativo?Non posso aggiornare poichè non ho l'AmigaOne500 collegata ad internet e quindi non uso l'AmiUpdate :kaput:
Help me!
collegala - aggiorna - scollegala 8)
Messaggioda Amy-Mor » gio ott 03, 2013 1:40 pm
Help me!
:ammicca:
Facile a dirsi, difficile a farsi...Non ho veramente il tempo materiale per smanettare dietro la configurazioni OS4 e relativo collegamento internet.
Per questo adoravo i pacchetti rilasciati fino al sesto.
Ma anche quel ca..o di sito Hyperion che non mi permette di fare il login... :incaz2:
uffà...qualche anima pia che me li spedisce?Se non erro samo disse che li salvava tutti. :rock:
Amy-Mor
Messaggioda NubeCheCorre » gio ott 03, 2013 5:38 pm
La configurazione internet di Amiga OS4 é la stessa che puoi fare sotto windows, quindi non dovresti incontrare problemi di sorta :felice:
Messaggioda tlosm » gio ott 03, 2013 5:45 pm
io sinceramente ho trovato amigaos 4 più semplice di windows :P... plug in cable and go..
Messaggioda samo79 » gio ott 03, 2013 9:51 pm
NubeCheCorre ha scritto:potevano farla meglio, quella pagina, esteticamente parlando... le tabelle!! argh!!!
Vabbè dai, una tabella è funzionale :felice:
Amy-Mor ha scritto:uffà...qualche anima pia che me li spedisce?Se non erro samo disse che li salvava tutti. :rock:
Si ma cosi te li dovresti installare manualmente uno per uno, considera che sono 56 update mica uno .. ci metti un botto cosi .. fidati fai prima a collegare l'Amiga in rete e scaricarteli normalmente, AmiUpdate li estrae tutti assieme e te li installa in automatico nei vari percorsi...
Messaggioda cip060 » gio ott 03, 2013 10:19 pm
EHM collegare il cavo alla scheda di rete e fa tutto in automatico vi fa schifo ?
