Benchmark Amiga Os 4.1 machines
Re: Benchmark Amiga Os 4.1 machines
Messaggioda tlosm » sab apr 20, 2013 9:33 am
potrei farlo quando ho un minuto anche se il programmatore di sysmon credo includerà tutti i risultati all'interno delle prossime release del programma almeno così ho inteso dal suo post.
Messaggioda zzd10h » dom apr 28, 2013 10:24 pm
Buongiorno,
For info, in the next release of SysMon (I hope this week), all the results from this thread will be included.
Grab :
http://zzd10h.amiga-ng.org/SysMon/SysMon_RageMem2.jpg
The configurations are stored in a text file (who can be edited by hand) and sorted by MIPS.
I will certainly, in a future release, add the possibility to add/remove our own RageMem results directly from SysMon.
In your opinion, the configurations have to be sorted :
-by MIPS order
-by alphabetical order
-by release date order
-by CPU family
-by ???
Is it a thing like that that you wanted ?
Thank you for your replies
I will not be able to include neither GFXBench because the first screen selection and the long long long execution time nor hard-drive speed (I don't know how to do it and devinfos still do it very well) .
Guillaume 'zzd10h'
zzd10h
Messaggioda tlosm » dom apr 28, 2013 11:16 pm
zzd10h ha scritto:Buongiorno,
Grab :
-by MIPS order
-by CPU family
-by ???
Guillaume 'zzd10h'
Great Guillaume! ... i m happy the because the community of amiganews.it do something useful for the amiga scene :) :happyboing:
Messaggioda Kyle » dom apr 28, 2013 11:46 pm
Cool :ride:
Messaggioda zzd10h » dom apr 28, 2013 11:59 pm
Of course, I have mentioned in the ReadMe that the benchmarks are taken from ikirsector.it
:ride:
But what about the order ?
With the MIPS order, my x1000 is "inferior" to my old Pegasos2.
But, in the facts, x1000 is very faster than Pegasos2...
zzd10h
Messaggioda tlosm » lun apr 29, 2013 12:27 am
I think the order Will be from slower to the faster in mips.
All the benchmark are like this sysinfo, aibb etc.. Docet ;)
about graphic benchmark there is a simple sdl benchmark on os4 depot but is good in the report
It make an txt probably you can simply include in Your project
http://www.os4depot.net/index.php?funct ... lbench.lha
Thanks too much :carucciiii:
You have to fix the report the boards are cyberstormppc not blizzardppc :-p
Messaggioda samo79 » lun apr 29, 2013 12:50 am
@Guillaume
Mmm the right way might be order them by CPU i think, need to be tested aniway
Messaggioda zzd10h » lun apr 29, 2013 10:48 am
@Samo79
Hi,
mail sent with new version of SysMon with sort by CPU family (and by MIPS in a separate text file).
it looks like that
http://zzd10h.amiga-ng.org/SysMon/SysMon_RageMem3.jpg
I have modified BlizzardPPC by Amiga1200 PPC or Amiga4000 PPC
@tlosm
Grazie,
SDLbench looks easier than GFXbench to include on SysMon.
I have noted it and will do it for the 'next-next' release (not this week)
Could you please open a thread on your forum to ask for SDLbecnh results (with GFXcard characteristic, AGP or PCI or PCI-E, memory, etc...) ?
I will be able to directly include them on SysMon (like with actual RageMem tab)
Here are my results
1) X1000 RadeonHD6670 2gb PCI-E
320x240 320x240 640x480 640x480
software hardware software hardware
Slow points (frames/sec): 20.9424 216.216 3.06279 54.4218
Fast points (frames/sec): 484.848 116.842 125.86 29.2204
Rect fill (rects/sec): 23011.2 81920 7922.63 42226.8
32x32 blits (blits/sec): 63015.4 30567.2 63015.4 29467.6
2) X1000 Radeon9250 256mb 128bits PCI (really bad comparing to A1XE-G3 results in SDLBench)
Slow points (frames/sec): 1.98511 228.571 0.248494 11.8343
Fast points (frames/sec): 171.812 116.948 42.8309 5.79159
Rect fill (rects/sec): 4708.05 80313.7 1339.88 117029
32x32 blits (blits/sec): 17138.1 30797 17066.7 163840
zzd10h
Messaggioda tlosm » lun apr 29, 2013 11:25 am
zzd10h ha scritto:@Samo79
Hi,
it looks like that
@tlosm
Grazie,
Here are my results
Ok i will ask to all the amiganews.it forum for make a sdlbench of their machines ... dont worry about the release i think we will need time made our job here :) ... but soon you will have all the machine results
thanks again
about the speed for sure will be bad because amiga one is using the warp3d accelleration for sdl , on the amiga x1000 probably you are using Wazp and the cpu is more stressed for this...
When Aeon will relase the warp 3d you will know the real power of the amiga x1000 in the Gfx :)
Messaggioda satiropan » ven giu 14, 2013 7:01 am
tlosm ha scritto:Si lo fa visualizzo sulle 2 uscite da sempre ma sempre ho 256mb disponibili ;)
scusa se ritornosultema, ma hai mai provato a riempire la ram video oltre 128mb?
Amighista dal 1988
http://www.oldfab.webs.com
satiropan
Messaggioda tlosm » ven giu 14, 2013 7:19 am
No mai fatto neanche Sulla Sam
Messaggioda tlosm » mer ago 28, 2013 12:34 am
tread aggiornato con la mia pegasos 2 :)
Messaggioda satiropan » sab set 07, 2013 3:29 pm
qui
un lieve miglioramento in ragemem, da quando ho su 2GB, sempre stessa velocità
Amighista dal 1988
satiropan
Messaggioda tlosm » gio nov 07, 2013 10:08 pm
Questa è la Pegasos 2 G4 1266mhz
Flops lo trovate su Os4depot.net
Messaggioda tlosm » ven feb 07, 2014 8:21 pm
Un paio di veloci bench al volo
Quake 1 software rendering 640x 480 AmigaOneXe 933mhz = 47.8 fps
Quake 1 software rendering 640x 480 Sam460 1ghz = 61 fps
