AmigaOS4.1FE e Enhancer Software
Re: AmigaOS4.1FE e Enhancer Software
Messaggioda Capitanvideo » lun gen 09, 2023 1:13 pm
Non ho visto offerte, a parte una versione più vecchia, su Amigakit store.
Cmq grazie per la risposta :felice:
Capitanvideo
Messaggioda amigait » lun gen 09, 2023 10:50 pm
Pegasos II Mos 3.1 OS4.1 FE
amigait
Messaggioda dogufo » mar gen 23, 2024 12:06 am
Certainly, I can provide guidance on using AmigaOS 4.1 on emulation software on a PC. Here are the answers to your questions:
Emulation Software:
For emulating AmigaOS 4.1, you can use WinUAE. WinUAE is a highly configurable Amiga emulator for Windows that allows you to emulate different Amiga models, including the A1200 and A4000 with various CPU configurations.
OS4.1FE Version:
You are correct. If you're aiming for maximum software compatibility with 680x0-based software, you should go for the 680x0 version of OS4.1FE. The PowerPC (PPC) version is for systems with PPC hardware, and since you're emulating an A1200 or A4000 with 68030 or 68040, the 680x0 version is the appropriate choice. vidmate app vidmate [url]https://myfiosgateway.win/
[/url]
Native PPC Software:
Yes, if you choose the 680x0 version of OS4.1FE, you won't be able to run native PPC software. However, it's worth noting that native PPC software for AmigaOS 4 is relatively limited, and most applications are still designed for 68k. The PPC capabilities are more relevant for the system's core functionality rather than individual applications.
Enhancer Software:
Enhancer Software is a package that enhances the capabilities of AmigaOS 4.1. It includes additional features, updates, and new applications. However, keep in mind that not all Enhancer Software components may be fully compatible or applicable to your emulation setup. It's recommended to check the compatibility of each component with your chosen emulator and OS version.
In summary, for your use case, I recommend WinUAE with the 680x0 version of AmigaOS 4.1FE. While native PPC software is limited, the 680x0 version will provide the best compatibility with classic Amiga software. As for Enhancer Software, you can explore its components based on your specific needs and compatibility considerations.
dogufo
Messaggioda AlfredOne » mer gen 24, 2024 4:34 pm
Ciao a tutti. Faccio un riassunto veloce su AmigaOS4.1.
L'ultima versione è la AmigaOS4.1 FE (final edition).
AmigaOS4.1 è solo per cpu PowerPC.
Ci sono varie versioni:
- AmigaOS4.1 Classic Edition gira sugli Amiga classici dotati di schede acceleratrici PowerPC (e quindi gira anche su WinUAE che emula amiga classici con schede acceleratrici PowerPC).
- AmigaOS4.1 per gli AmigaNG (X1000, X5000, Sam460, AmigaOne XE, Pegasos2).
Le versioni sono identiche, cambiano solo alcuni moduli del kickstart che si interfacciano all'hardware specifico delle macchine.
Se si vuole usare sotto emulazione, ci sono due possibilità adesso:
1) usare WinUAE (+ plugin qemu che emula la CPU PowerPC)
2) usare direttamente QEMU (minimo la versione 8.2).
Con WinUAE emuli amiga classici dotati di scheda PowerPC (Quindi serve AmigaOS4.1 Classic Edition)
Con QEMU 8.2 emuli direttamente gli Amiga NG (Quindi serve AmigaOS4.1 per la macchina specifica che vuoi emulare)
Attualmente con QEMU 8.2 sono emulate:
- Sam460
- Pegasos2
- AmigaOne XE (lavori in corso, non so se è già disponibile)
Secondo me per emulare AmigaOS4.1 adesso conviene usare QEmu8.2 per questi motivi:
1) la versione QEMU usata in WinUAE è molto più vecchia
2) emulando le macchine NG non ci sono i limiti di RAM delle macchine classiche
3) con il passthrough USB si possono usare direttamente dispositivi USB
4) Tra poco uscirà un driver virtuale che potrà sfruttare direttamente i driver grafici della macchina ospite
Per esperienza personale, attualmente l'emulazione Pegasos2 è la migliore.
Note:
Non esiste la versione 680x0 di OS4.1FE. OS4.1 è solo per PowerPC.
Esiste la versione OS4.1 Classic Edition che serve a gestire l'hardware della scheda acceleratrice PPC e dell'amiga classic (avrà i driver per gestire i chip custom dell'amiga).
Il software PowerPC per AmigaOS4.1 gira su tutti i tipo di AmigaOS4.1 indifferentemente.
I vecchi software per motorola 68000, su AmigaOS4.1 girano in modo trasparente grazie ad un emulatore(Petunia) che si attiva automaticamente, ma gira solo il software scritto in modo OS-friendly.
I software che accedono direttamente ai chip custom Amiga, non funzionano su AmigaOS4.1. Puoi usarli lanciando l'emulatore FS-UAE (che come WinUAE emula l'intera macchina Amiga, e non solo la CPU).
Commodore Plus4
Amiga500 Kickstart1.3
https://project4a.eu/
AlfredOne
Messaggioda vagappc » lun lug 29, 2024 7:50 pm
Enchancer da nuova vita al 4.1, ma è un requisito di Warp3dNova che vanno comprate a parte.
Risolve un sacco di rogne, inoltre puoi usare SFS, le prefs sono migliori e aggiunge tante piccole migliorie.
vagappc
