La lista degli Update da dopo l'uscita di Os 4.1.6
Re: La lista degli Update da dopo l'uscita di Os 4.1.6
Messaggioda samo79 » lun ott 07, 2013 7:01 am
Amighi !
Hanno appena rilasciato tramite AmiUpdate il nuovo kernel 53.58 ed altre cosine interessanti :ride:
Kernel 53.58 (2013-09-27)
- Accelerated copies on 440ep/460ex systems.
- Accelerated copy & move operations on all systems except X1000.
- Fixed memory munge pattern on 460ex systems.
- Fixed bugs in Reaper task.
- Added new StackTrace(), ObtainDebugSymbol() and RelaseDebugSymbol() debuggin functions.
- Added new Strlen() utility function.
- Fixed bugs when suspending a Task.
- Changed Alert() to suspend a task properly.
- Changed Read/WriteTaskContext() API to allow or easier extension.
- Updated kdebug tool to make it easier to use and added new commands.
- Fixed RemoveSplayNode() utility function.
Tempo di benchmark :ammicca:
Ed inoltre:
DOS.library 53.145
- Added FileHandleScan() function.
- MakeLink() fixes.
- Fixed DismountDevice() restart hole.
- Added many more dos packet emulations.
- Fixed appdir server to flush entries where the execute has disappeared.
- Added GetFileSystemVectorPort() and ResolvePath() functions.
- Fixed a record locking issue when using non-immediate mode and a collision is detected.
- Improved compatibility of the ExNext() emulation.
- Bug fixes.
GrimReaper 53.16
- Uses new stack tracing and symbol query kernel API.
- Disables the "Continue" button if the cause was a dead end alert.
- Added support for Alert() handling which moves the IP forward correctly.
- Bug fixes.
NewLib.library 53.28
- Added _get_osfhandle() function for getting underlying BPTR file handles.
- Added amiga_platform.h header file for Amiga-only extensions.
- Path name translation functions are now useable from program code.
- Fixed '.' and '..' directly entries in opendir().
- Added statvfs() and fstatvfs() functions.
- Added F_DUPFD support in fcntl() function.
- Added ftruncate64() and truncate64() functions.
- Added termios.h header and functions.
- Added initstate(), setstate(), srandom() and random() functions.
- Added glob() and globfree() functions.
- Optimized movemem() routine.
- Fixed fchown() function to work properly from _fstat_r() entry point.
Messaggioda tlosm » lun ott 07, 2013 11:37 am
HANNO AGGIORNATO IL KERNEL!!! tutti su Amiupdate!!!
azz samo sono arrivato secondo
quindi ora siamo al 4.1.6.60 8)
mi tocca provare se ora la 7750HD funziona sulla 460 ;)
Messaggioda samo79 » lun ott 07, 2013 12:06 pm
:eheh2: :eheh2:
Messaggioda tlosm » lun ott 07, 2013 12:56 pm
Con la mia configurazione 460 lite e 6670HD
test rage mem : incremento della velocità da 0.10% al 3% sulla cache cpu fino ad arrivare ad un 12% sul busvideo
Mentre su sdlbech si va da uno 0.11 fino all'incremento del 111,76 %del 32x32 blits....
Veramente niente male!
ma il softreset sulla 6670 continua a non funzionare che palle!
Ultima modifica di tlosm il lun ott 07, 2013 1:13 pm, modificato 1 volta in totale.
Messaggioda MacGyverPPC » lun ott 07, 2013 1:08 pm
Non vedo l'ora di provare le differenze sulla 440. :felice:
Messaggioda tlosm » lun ott 07, 2013 2:20 pm
7750HD continua ad essere incompatibile con la 460 :(
Messaggioda samo79 » lun ott 07, 2013 4:41 pm
Ho solo fatto un paio di test veloci ma ho notato che ora i DVD vanno a piena velocità pure sulla mia Sam440 con la Radeon puzzosa, finalmente !
Messaggioda Kyle » lun ott 07, 2013 5:50 pm
Uff io ho la 460 al palo causa assenza case... Lorianooo?!? :scherza:
Messaggioda Amy-Mor » lun ott 07, 2013 5:56 pm
Kyle ha scritto:Uff io ho la 460 al palo causa assenza case... Lorianooo?!? :scherza:
Ed io che sono nelle mani di Samo x avere gli aggiornamenti? :ultralol:
Amy-Mor
Messaggioda AMIGATV » lun ott 07, 2013 8:56 pm
samo79 ha scritto:Ho solo fatto un paio di test veloci ma ho notato che ora i DVD vanno a piena velocità pure sulla mia Sam440 con la Radeon puzzosa, finalmente !
era ora.... :felice:
Messaggioda AMIGATV » lun ott 07, 2013 9:00 pm
tlosm ha scritto:Con la mia configurazione 460 lite e 6670HD
vedo che anche la cpu ha avuto un buon incremento di velocità prova a fare qualche test che faccia vedere questo miglioramento......
Messaggioda Kyle » lun ott 07, 2013 9:10 pm
tlosm ha scritto:ma il softreset sulla 6670 continua a non funzionare che palle!
A me funziona bene (o meglio funzionava fintanto che avevo la 460 installata; una volta avevo il tuo stesso problema e dipendeva dal monitor che non riusciva a riagganciare il segnale video dopo un soft reset (mi rimaneva la schermata nera): hai modo di fare delle prove con un altro monitor? :riflette:
Messaggioda Kyle » lun ott 07, 2013 9:11 pm
Mmmm, però mi sembra di capire che il dma sulla sata onboard delle 460 non è stato ancora attivato :triste:
Messaggioda NubeCheCorre » lun ott 07, 2013 9:36 pm
@samo
mo provo anche io :ride:
Messaggioda tlosm » lun ott 07, 2013 9:58 pm
che test? ho usato sysmon e ho comparato il mio risultato con quello di oggi
