Errore script Amiganews con Android Opera
Messaggioda Raffaele » dom nov 04, 2012 7:20 pm
Da qualche giorno ho installato Opera Androud sul mio SGII...
Postando su Amiganews qualche volta ho questo errore, che cmq. non è niente di grave perché basta tornare indietro e inviare nuovamente il post...
Pensavo fosse comunque da segnalare a Ikir...
CGIWrap Error: Script Execution Failed
CGIWrap encountered an error while attempting to execute this script:
Error Message: No such file or directory
Error Number: 2
This message usually indicates there is a problem with the script itself. Often this indicates either that the #! line of the script is incorrect, or the script was uploaded in binary mode instead of ascii mode. Check to make sure that the script does not have control-M's at the end of every line. That will prevent it from executing. An easy fix that takes care of this most of the time is to put '#!/.../perl --' instead of '#!/.../perl' on the first line of the script. This is typically a problem if the script was edited or uploaded from a DOS/Windows/Macintosh station to a unix based server.
If you are not the owner of this script, please forward this error and the URL that caused it to the script owner. That is often the component in the URL right after /cgiwrap/.
Server Data:
Server Administrator/Contact: [no address given]
Server Name: amiga.ikirsector.it
Server Port: 80
Server Protocol: HTTP/1.0
Virtual Host: amiga.ikirsector.it
Request Data:
User Agent/Browser: Opera/9.80 (Android 2.3.5; Linux; Opera Mobi/ADR-1210091050) Presto/2.11.355 Version/12.10
Request Method: POST
Remote Address: 31.191.180.240
Remote Port: 50870
Query String: mode=reply&f=4&sid=b17cb3989af3be0131239f7874057639&t=17076
Referring Page: posting.php?mode=reply&f=4&t=17076
Re: Errore script Amiganews con Android Opera
Messaggioda samo79 » lun nov 05, 2012 12:35 am
L'ho notato pure io ma qui accade molto di rado ... hai fatto bene a segnalarlo
Messaggioda MacGyverPPC » lun nov 05, 2012 12:51 am
Scusa, io su GSII ho su Chrome che va una meraviglia, comunque va benone anche il browser standard o Firefox su Android. Ah, ci dev'essere anche l'ottimo SkyFire o come cavolo si chiama, che usavo sul vecchio Nokia ExpressMusic e sull'N8, che sui nokia a differenza d'altri era una scheggia su Symbian e dava una bella visualizzazione desktop come sugli attuali Android.
:felice:
Messaggioda cip060 » lun nov 05, 2012 12:51 am
non e' un problema con android e opera
anche a me con OWB e mos lo fa'
basta ricaricare la pagina e ritorna la pagina caricata bene bo!
me lo ha fatto anche con firefox per dirla tutta
Messaggioda MacGyverPPC » lun nov 05, 2012 12:55 am
Me l'ha appena fatto rientrando nel tread con Chrome... quindi come dice Cip.
Questo è un problema che capita spesso su AmigaNews ma dev'essere legato al server che lo ospita, che a volte va anche in blackout .
Messaggioda cip060 » lun nov 05, 2012 12:16 pm
Be saranno 2 giorni eh!!mica un mese
Messaggioda ikir » mer nov 21, 2012 3:15 pm
Qui non mi è mai successo ne con Safari ne Safari mobile.
Se è un problema minore non c'è da preoccuparsi... non posso dire nulla ma ci saranno novità su Amiga News.it, portate un po' di pazienza.
Messaggioda cip060 » mer nov 21, 2012 7:27 pm
Infatti non lo fa' piu' :ride: :ride:
Torna a Amiga News.it
