ReportPlus v8.1 Multipiattaforma
Messaggioda AMIGASYSTEM » ven feb 19, 2021 12:42 am
Author: James Jacobs
ReportPlus: Nuova versione di Report+, una Multi Utility freeware ReAction-based per OS3.9 BB2, OS4, MOS con molte funzioni utili tutte da provare !
ReportPlus v8.1: Download (Tutte le versioni)
1. It is a friendly, enhanced replacement for the official Commodore bug
reporting tool (V40.2), optionally sending emails automatically.
2. It can generate/edit Aminet-style and OS4Depot-style readmes.
3. It can edit A3000/A4000-type battery-backed memory.
4. It can access the official manufacturer and product ID registries.
5. It can view IFF/RIFF files and their component chunks.
6. It can perform batch processing on icons.
7. It can convert between various ASCII formats.
8. It can show directory byte usage for any path, optionally also
fixing protection bits and/or deleting files.
9. It can take a snapshot of a path and later compare the
path against this, showing added, missing and changed files.
Re: ReportPlus v8.03 Multipiattaforma
Messaggioda AMIGASYSTEM » dom mar 07, 2021 12:13 am
Aggiornata News alla versione v8.03
Re: ReportPlus v8.1 Multipiattaforma
Messaggioda AMIGASYSTEM » ven apr 30, 2021 8:34 am
Aggiornata la News alla versione v8.1
