REDPILL Game Creator v0.8.2
Messaggioda AMIGASYSTEM » dom nov 15, 2020 12:52 pm
RedPill v0.4.7: Amiga Game Creator con supporto AGA
Autore: Zener
REDPILL Game Creator: Download
Info sul Programma:
- A tool to empower people to create many games for Amiga without programming knowledge.
- Easy to use and at the same time allow to do complex things.
- More a toy to play with than a professional tool, not having thousands of features but instead have few features that work very well.
- Allows people to create 2D games with the true Amiga feeling!
- It is free.
- It is still in development.
- A tool aimed to create professional games, you will need to learn programming for that purpose.
- No need to be a programmer, but if you are one, then Asm, C, Blitz, Amos, etc. are more powerful than RedPill. Use RedPill if you are not good at programming, you want to develop fast or you want to have some fun :)
- It is not suitable to create any type of game, but you can try it anyway.
- It is not going to grow until it becomes Unreal, Unity, GameMaker or Skynet, it is still a hobbie project.
- The priority is allowing Amiga users to create games, power and performance come second.
Requisiti:
- 020 Processor
- 2MB of RAM for the Player.
- HardDrive and 3MB of RAM for the Editor.
- For big projects more resources may be needed.
- In case you are using a Vampire V4SA you will need core 74XX or higher.
- In ApolloOS games can be played with joystick but keyboard an mouse input is not working.
