Wayfarer v1.8 MOS
Wayfarer v1.8 MOS
Messaggioda AMIGASYSTEM » gio ott 08, 2020 12:37 pm
Wayfarer: Nuovo Browser Internet per MOS basato WebKit che consente di navigare su gran parte dei Siti Web dove OWB non poteva accedere a causa del suo motore non aggiornato.
Wayfarer supporta Applicazioni Google Docs, Google Drive e Google Maps, o Applicazioni di Messaggistica come Whatsapp,Telegram o Discord, richiesto MorphOS 3.14 con almeno 1 GB di RAM
Wayfarer: Download (News aggiornata v1.8)
Re: Wayfarer v1.0 MOS
Messaggioda AMIGASYSTEM » dom ott 18, 2020 9:30 pm
Aggiornamento 1.2
- Implemented Quick Links
- Implemented favicons
- Enabled support for WebP images
- Updated libcurl
- Fixed blob: support
- Fixed file name encoding and cookie issues in downloads
- Fixed Bookmarks menus to show more depth levels
- Fixed a crash on exit caused by the password autofill manager
- Fixed a crash on exit in WebCore's fileapi
- Fixed Copy image URL context menu function
Re: Wayfarer v1.0/v1.2 MOS
Messaggioda cip060 » lun ott 19, 2020 1:15 pm
Aggiornamento 1.3
- Minor perofrmance improvements, mostly on G5
- Fixed lists in settings displaying no text, sometimes crashing
- Fixed url string background offsets
- Activate an exiting tab instead of adding a new one for downloads/bookmarks/settings
- Fixed tab buttons becoming invisible or corrupt on some configs
- Fixed an issue where adding a link to quick links via menu would display them in a wrong location in the Bookmarks tab
- Fixed quicklink buttons to respect releasing mouse of of button bounds
Re: Wayfarer v1.0/1.2/1.3/1.4 MOS
Messaggioda AMIGASYSTEM » lun ott 19, 2020 10:10 pm
Aggiornamento v1.4
- Fixed an issue where adding a link to bookmarks via menu would try to insert it to a wrong tree node in a Bookmarks tab
- Rolled back some compilation setting tweaks since they were causing issues on some G4 cpus
Re: Wayfarer v1.0/1.2/1.3/1.4/1.5 MOS
Messaggioda AMIGASYSTEM » gio ott 29, 2020 12:59 am
Aggiornamento 1.5
- Wayfarer now starts via a loader app
- Added an early loading splash window, shutdown splash window (via loader)
- Crashes in Wayfarer are caught by the loader which cleans up the windows and as many resources as possible, usually allowing a restart of the application
- Implemented a way to send bugreports directly after a crash, including debug information and the most recently visited URLs
- Added Eruda web inspector integration
- It's now possible to select a session to load on application start or automatically re-store the previous state
- Sessions store the active tab
- Enabled the Intersection Observer in WebCore
- Reduced the number of SQL file writes
- Separate interpolation setting for image links
- Quicklink buttons respect favicon settings, update on favicon changes
- Added a file requester to the downloads path in Settings
- Added quit confirmation requester settings
- Fixed navigating to wayfarer:// links without explicitly doing it from the menu
- Fixed CPU clock detection code
- Fixed a double-start issue where the 2nd instance would not quit
- Fixed a potential crash in favicon code
- Fixed right shift key handling in some hotkeys
- Fixed tab button backgrounds
- Fixed ghost effects after closing tabs on some MUI configurations
Re: Wayfarer v1.0/1.2/1.3/1.4/1.5/1.6 MOS
Messaggioda cip060 » mar nov 17, 2020 5:29 pm
Siamo arrivati alla versione 1.6 in pochi mesi
Wayfarer v1.6
Fully WSIWYG printing system
Spell checking support
Undo/Redo support
Networking thread optimized to use less CPU
Built with optimized OpenSSL for faster HTTPS connections
Added tons of help bubbles across the app
Added an option to log console messages to ramdebug
Added quit requester options to the Settings tab
Added a setting to popup downloads tab on new downloads
Tries to use current tab for Downloads/Settings/Bookmarks if empty
Added an Error column to the download list
Added a context menu to the download list (copy path/url)
Download URL updates on redirects
'Download' Context menu will now use OpenURL for ftp/mailto links
Fixed resuming of downloads after error
Fixed to handle multiselection in the download list
Improved the Stop/Reload button; Reload forces a full reload (disregarding disk caches)
Fixed ctrl key handling in the text editor
Fixed a nasty 5 random-address bytes memtrash at the end of JS Promise handling that was the main source of instability on pages like PayPal, ebay, etc
Fixed a use-after-free in WTF's file system support
Fixed a crash when editing quicklink submenus
Prevents re-opening screen when loading a session
Disabled a bunch of memtrashing code paths in audio processing support
Fixed an out-of-mem crash in WebCore's JPEG decoder
Fixed a crash when adding quicklinks
Fixed size overflow on >4GB downloads
Fixed a potential browser crash after a hibernation
Messaggioda divina » mer dic 02, 2020 2:37 am
è ottimo questo nuovo browser, lo utilizzo con frequenza e ad ogni nuova versione viene aggiunta una feature importante (tanto di cappello ai due devs di MorphOS)
Unico particolare, inizia a starmi stretto anche il PowerMac G5; si comprende ormai l' esigenza di un hardware x64 per l' utilizzo agevole di un browser moderno
Messaggioda AMIGASYSTEM » gio dic 10, 2020 5:27 pm
Aggiornata la news, update v1.8
Re: Wayfarer v1.8 MOS
Messaggioda Mabo81 » mer ago 02, 2023 12:54 pm
Raga sapete dirmi se ha il supporto flash/java o se si deve andare di script come l'altro? Grazie :felice:
Mabo81
Messaggioda cip060 » gio ago 03, 2023 4:27 pm
siamoa V 6.0 :ride:
Messaggioda AMIGASYSTEM » gio ago 03, 2023 4:49 pm
@Mabo81
Flash non lo usa più nessuno, Adobe da luglio 2017 annunciò il fine vita, nessun Browser supporta più il Flash e nessuna applicazione Web basata su Flash funziona più, per farlo devi procurarti un vecchio FlashPlayer e un vecchio PC.
Riguardo java, so che su Wayfarer ci sono stati tanti fix, al momento non lo uso su MOS emulato, continuo ad utilizzare OWB che è più veloce.
Messaggioda Mabo81 » gio ago 03, 2023 5:40 pm
Codice: Seleziona tutto
[quote="AMIGASYSTEM"]@Mabo81
Riguardo java, so che su Wayfarer ci sono stati tanti fix, al momento non lo uso su MOS emulato, continuo ad utilizzare OWB che è più veloce.[/quote]
Sono fuori dal giro da un po di tempo... Se non sbaglio youtube va di flash... Ma con Mos mi ricordo che andavo forse di HTML5 con OWB :mah: o via emulazione tablet ipaddo o.O
Mabo81
Messaggioda AMIGASYSTEM » gio ago 03, 2023 6:08 pm
Non mi risulta, che io sappia Youtube ha abbandonato da quasi 10 anni il FlashPlayer, al suo posto HTML5 !
A quanto pare sei rimato indietro di qualche decennio, ogni tanto accendi il PC o AROS One :ride:
Messaggioda Mabo81 » gio ago 10, 2023 7:38 pm
@cip060
siamoa V 6.0
Cipollino beo beo :tie:
Ti trovi meglio con Odyssey o questo Wayfarer ? :mah:
Ho rispolverato il macmini :ultralol: :fuck:
Mabo81
Messaggioda cip060 » ven ago 11, 2023 10:29 am
Odyssey nonostante non sia piu aggiornato da tanto resta comunque molto piu veloce non ho trovato siti che no riesco a navigare
wayfarer nonostante sia piu lento anche sul mio Imac g5 2.1 ghz e' dcisamente potente e aggiornato apre qualsiasi sito anche amazon per dire
Li uso entrambi con grande soddisfazione
