ReportPlus v7.93 Multipiattaforma
Messaggioda AMIGASYSTEM » lun set 14, 2020 11:43 pm
Author: James Jacobs
ReportPlus: Nuova versione di Report+, una Multi Utility freeware ReAction-based per OS3.9 BB2, OS4, MOS (per questo OS ancora la vecchia versione 7.92) con molte funzioni utili tutte da provare, Codice Sorgente Incluso.
ReportPlus v7.93: Download (Tutte le versioni)
1. It is a friendly, enhanced replacement for the official Commodore bug
reporting tool (V40.2), optionally sending emails automatically.
2. It can generate/edit Aminet-style and OS4Depot-style readmes.
3. It can edit A3000/A4000-type battery-backed memory.
4. It can access the official manufacturer and product ID registries.
5. It can view IFF/RIFF files and their component chunks.
6. It can perform batch processing on icons.
7. It can convert between various ASCII formats.
8. It can show directory byte usage for any path, optionally also
fixing protection bits and/or deleting files.
9. It can take a snapshot of a path and later compare the
path against this, showing added, missing and changed files.
Visitano il forum: Nessuno e 94 ospiti
