RNOPublisher v1.0 Multipiattaforma
Messaggioda AMIGASYSTEM » ven lug 31, 2020 8:35 am
RNOPublisher: Programma Multitiapttaforme realizzato con Hollywood per la creazione PDF, RNOPublisher è facile da usare ed è disponibile per AROS, MorphOS, OS4, OS3 (RTG) e WarpOS (RTG).
Autore: jPV^RNO
RNOPublisher v1.0: Download (Tutte le versioni)
Features:
- Supports the most common page sizes in portrait and landscape modes
- Freely placeable text boxes, images, PDF links, and graphical objects
- PDF links can point to document pages or web links
- Supports base fonts that don't affect the file size
- Custom TTF fonts can be embedded into documents
- PDF outlines (table of contents) support
- User creatable page templates
- PDF exporting supports passwords and compression options
- Constrained mouse movement and resizing using qualifier keys
- Additional document saving and loading in its own format
- Drag & drop loading of documents, pictures, and text files
Requirements:
- AmigaOS 3.0, fast CPU (or emulator), plenty of memory, and RTG setup
- MUI 3.8 or later (http://aminet.net/package/util/libs/mui38usr)
- codesets.library (http://aminet.net/search?query=codesets)
- guigfx.library (http://aminet.net/package/dev/misc/guigfxlib)
- render.library (http://aminet.net/search?query=renderlib), v31 is probably
the best for <040 CPUs
- TextEditor.mcc (http://aminet.net/search?query=mcc+texteditor)
Installation:
Copy the whole directory anywhere you want and just launch the program.
Usage Notes:
- Remember to click the "Apply changes" button after any modifications to
objects.
- Double-clicking an object moves it one step forward in the layer stack.
- Move several objects at once by multi-selecting them from the object list.
- Document title + author fields are saved to both RNOPublisher and PDF files.
- Auto saving only works on a document that has been created and saved.
- Templates are stored in the Templates directory in the program directory,
and users can modify them or create new ones from them.
- Qualifier keys when handling objects with the mouse:
Shift . . - Constrains object movement/resizing to vertical direction
Ctrl . . . - Constrains object movement/resizing to horizontal direction
Alt . . . - Retains the aspect ratio when resizing an object
- "Hidden" keyboard shortcuts in addition to marked shorctuts:
Esc . . . - Abort dragging or resizing of an object
F1 . . . . - Cut a page
F2 . . . . - Copy a page
F3 . . . . - Paste a page
F5 . . . . - Cut an object
F6 . . . . - Copy an object
F7 . . . . - Paste an object
PageUp . . - Jump to the previous page
PageDown . - Jump to the next page
Home . . . - Jump to the first page
End . . . - Jump to the last page
Settings
Program settings are to be found in the program's pull-down menu and they will
be saved to the ENVARC:Hollywood/com.wmhost.jpv.rnopublisher file.
Re: RNOPublisher v1.0 Multipiattaforma
Messaggioda ghillo » ven lug 31, 2020 1:12 pm
L'HO provato ieri sera, devo un attimo capire come funziona ma sembra interessante. Pensavo che si potessero modificare i file PDF , ma non riesco a caricarli .
Quindi si possono creare ma non modificare, sarebbe utile anche poterli editare i PDF
ghillo
Messaggioda schiumacal » ven lug 31, 2020 1:27 pm
L'ho appena scaricato, più tardi lo installo e provo per benino...
Ps.
Per quanto riguarda i file .pdf e sua eventuale modifica, dipende molto da come questo tipo di file è stato salvato.
Ad esempio, anche Word della Microsoft salva un documento nel formato .pdf , ma lo salva come un'intera immagine, quindi alla fine non risulta più modificabile.
Idem Photoshop, salva nel formato .pdf ma come immagine.
Bisognerebbe provare un file .pdf che sia realmente formato testo.
Messaggioda pvanni » dom ago 02, 2020 3:52 pm
L'ho scaricato anch'io, e sembra che si possano aprire solamente file in formato
proprietario, e non pdf.
pvanni
Messaggioda schiumacal » dom ago 02, 2020 4:47 pm
Qualcuno ha provato a creare un file .pdf e poi leggerlo con qualche tool di Windows ?
Magari, al momento, non legge file .pdf esterni, ma i .pdf che crea lui possono essere letti da altri. In tal caso vuol dire che lavora con i .pdf, in caso contrario non serve a niente questo software.
Messaggioda AMIGASYSTEM » dom ago 02, 2020 6:47 pm
Esporta file in PDF quindi è sicuro che sia compatibile su Windows o altri Computer, il PDF è un file di Stampa Standard, non ho fatto alcun test ma lo ha fatto Seiya, puoi vedere il video tutorial QUI, anche se poi ha dovuto ripiegare su AfA One per terminare il test con esito pisitivo.
Messaggioda schiumacal » dom ago 02, 2020 8:14 pm
Si OK... era per capire bene quello che viene detto qui:
pvanni ha scritto:L'ho scaricato anch'io, e sembra che si possano aprire solamente file in formato
Ovvio che non apre file proprietari, ma .pdf veri e proprio, ovvio anche che permette la creazione di .pdf totalmente da zero e che quest'ultimi possono essere tranquillamente esportati.
Da ciò deduco che non sono file proprietari.
Messaggioda Seiya » dom ago 02, 2020 9:30 pm
è un editor di PDF in cui voi create da zero un documento e poi lo esportate in PDF. Se dovete fare una cosa lunga e salvare di volta in volta crea un file ".rnd" che il suo formato proprietario.
Il PDF creato funziona molto bene anche dai vari lettori per altri OS più moderni. L'editor è molto semplice e non supporta la formattazione del testo avanzato come fanno multi word-processor e publisher vari. Niente testo in grassetto, corsivo o sottolineato, non si possono associare link a parole o oggetti sullo schermo, ma dovete creare, ad esempio, un "oggetto link".
Si poteva fare molto di più sopratutto per la parte testo e anche sulla correzione automatica dato che il box di scrittura è piccolo e andare a cercare errori diventa un po' complicato. Su Amiga comunque è il primo in assoluto e devo dire che probabilmente arriveranno plugin per migliorare la parte di scrittura. Del resto grazie ad Hollywood gli aggiornamenti dovrebbe essere abbastanza frequenti.
Consiglio: è molto buono e già così si merita una medaglia d'oro se fosse recensito in una rivista
Messaggioda ghillo » dom ago 02, 2020 11:06 pm
Hai ragione Seiya , bisognerebbe propio dargli una medaglia d'oro ad Amiga mancano propio quei software che ci permetterebbero di fare l'80 % delle cose sul nostro sistema senza dovere accendere un PC con Windows .
Comunque sarebbe utile poter modificare dei file PDF , mia figlia che va al liceo quest'anno gli è arrivato un documento in pdf che doveva modificare inserendo dei dati negli appositi campi.
Comunque veramente bravissimo il programmatore
ghillo
Messaggioda AMIGASYSTEM » lun ago 03, 2020 12:44 am
ghillo ha scritto:mia figlia che va al liceo quest'anno gli è arrivato un documento in pdf che doveva modificare inserendo dei dati negli appositi campi.
Riguardo i documenti PDF anche on-line con campi per scriverci sopra non occorre un Editore PDF che serve ad altro, per scrivere nei campi occorre avere installata l'ultima versione di Acrobat Reader, tutti gli altri Reader o ignoreranno o non mostreranno i campi.
Altri motivi di non scrittura ma anche di divieto di copi-incolla è dato dalle varie protezioni inserite nel documento PDF che in molti casi si fa fatica a sboccarli, in questo caoo occorrono particolari software.
Messaggioda amiwell79 » gio ago 06, 2020 7:43 pm
Per la cronoca senza il mio supporto e le mie idee il programmatore non avrebbe fatto nulla :eheh:
amiwell79
Messaggioda ghillo » gio ago 06, 2020 9:59 pm
Lo so ed infatti sei stato bravissimo :rock: :rock:
Non è che hai qualche altra ideuccia visto che conosci il programmatore.
Una curiosità ma come hai fatto a convincerlo ,lo conosci di Persona e di dove è.
ghillo
Messaggioda amiwell79 » gio ago 06, 2020 10:04 pm
l'ho contattato per caso e gli ho proposto la cosa, adesso siamo in buoni rapporti :felice:, al momento e' indaffarato
amiwell79
Messaggioda amiwell79 » gio ago 13, 2020 9:20 pm
si poi attualmente non ho idee :ride:
amiwell79
