WinUAE 4.4.0 Beta 7/8/9
Messaggioda AMIGASYSTEM » dom giu 28, 2020 12:33 pm
WinUAE 4.4.0 Beta Series: Ancora 3 nuove beta in pochi giorni che anticipano la versione Stable.
Autore: Toni Wilen
WinUAE v4.4.0 Beta 9: Download
WinUAE v4.4.0 Beta 9: (64Bit): Download
Novità Beta 7
- Fixed Misc panel statefile text box working strangely when typing. Also default statefile path and .uss extension is added if missing.
- CPU multiplier in prefetch mode (support added in b1) wasn't saved to config file.
- CPU multiplier is set to pre-4.4 defaults when loading old config files.
- CPU multiplier (if prefetch/ce) is changed to default multiplier when CPU model is changed.
- "Default" filter mode now enables aspect ratio correction and scales to window/screen size. Disabled previously active GUI elements that are not compatible with current filter mode.
Novità Beta 8 (RC1)
- More "Default" filter adjustments: enable aspect ratio correction only if current aspect ratio is not close enough to 4:3. Enable scaling to current window/screen size only if current window/screen is "too" large or small. Main reason for this change is to keep old behavior (no scaling or aspect ratio correction if default window/screen size but enable scaling/aspect ratio correction if window is larger or smaller)
- Beta tag removed.
Novità Beta 9 Final (RC1)
Only few previously missed CPU fixes due to a bug in my tester..
- TRAPcc and CHK2 exception stack frame fix. Stacked PC was not pointing to next instruction. (CPU tester didn't validate 68020+ exception stacked PC field. Fixed and retested.)
- 68060 LPSTOP illegal instruction if second word is not 0x01C0 and privilege violation due to new SR not having S-bit set stack frame had wrong stacked PC.
- 68060 STOP privilege violation if new SR didn't have S-bit set (68060-only special case) exception stacked PC was wrong.
Re: WinUAE 4.4.0 Beta 7/8/9
Messaggioda AMIGASYSTEM » lun giu 29, 2020 7:33 pm
Aggiornata la News con una nuova e probabile "Final Beta" che anticipa l'uscita della versione Stable
