RNOInfoScreen v1.7 OS3/OS4/MOS/WOS
Messaggioda AMIGASYSTEM » ven lug 26, 2019 12:11 pm
RNOInfoScreen è un Front-end per OS3, OS4, MOS e WOS che permette di leggere le informazioni sui Tag inclusi gli Artwork se presenti nel file MP3, l'applicazione consente inoltre la ricerca delle Cover via Internet o utilizzare direttamente le immagini presenti nella cartella o volume che contiene gli MP3.
RNOInfoScreen v1.7 OS3/OS4/MOS/WOS: Download
Features
- Detects the running player and gets the information from it automatically
- Supported players: Jukebox, SongPlayer, AmiNetRadio, TuneNet 2.4 or later, AmigaAMP 2.22 or later, MPlayer (MUI), DAPlayer, RNORadio
- Displays information about the previous and currently playing songs
- Displays album art images, if found, from song's directory, via Internet (Cover Art Archive), or as embedded images
- Configurable cache for downloaded images
- A clock display
- Fullscreen and windowed (sizeable) modes
- Screen blankers can be disabled
- Last.fm scrobbling support on MorphOS with the UniScrobbler script
- Can be used as a MorphOS blanker with the included binary file
- Keyboard controls for prev/pause/play/next
- Hidden volume control/display by using the up/down cursor keys, or the middle mouse wheel
- Hidden quit (top left if in fullscreen mode) and screen swap (top right of screen if in fullscreen mode) by single left mouse-click on corner pixels.
- ARexx support
Requirements
- MorphOS 3.x, OS4, or AmigaOS 3.x
- A working ARexx environment (rexxsyslib.library installed on MorphOS)
- On a classic Amiga: high or true color RTG, KS3.0+ and plenty of mem, but no guarantee how well it works on real machines, probably not too well.
Installation
- Copy an executable or the whole directory anywhere you want, no further installation required
- To use as a blanker in MorphOS, copy the RNOInfoScreen.btd file to the
SYS:Classes/Blankers directory or use the provided install script.
Usage
- Start the music playback on any of the supported players and then just launch this program
- Double-click or rcommand-f switches between fullscreen and windowed modes
- Displayed elements can be enabled and disabled from the pull-down menu
- Move the mouse to get control buttons displayed
- Volume can be controlled with the mouse wheel or from the keyboard, holding the shift key changes it in larger increments in MorphOS
Keyboard controls:
Right - Next
Left - Previous
Up - Volume up
Down - Volume down
Space - Pause
Enter - Play
Esc - Quit
