Exutil v1.1 OS3/OS4/MOS/AROS68k/Win
Messaggioda AMIGASYSTEM » lun mar 11, 2019 7:16 pm
Exutil: Batch renames picture files by Exif date
Exutil v1.1 OS3/OS4/MOS/AROS68k/Win: Download
This is a small MUI based utility that batch renames pictures by date sorted names based on Exif date information or by file's
date. You can Rename pictures with a common name part (Default is Pic_), followed or lead by date and a counter For every calendar day. Additionally the Exif date and time can get written to the file comment of each file in case an Exif data structure has beenfound. As the program conserves the filename extension For renaming you can use Exutil to batch Rename other files than pictures, too. Obviosly no Exif information can get used then. You also can skip date information completely and rename it just by a common name. If files are pictures the program can show according thumbnails during the renaming process or without renaming as preview. Program written with Hollywood and available for all Amigaish flavours (68k, MorphOS, OS4, AROS x86).
Requirements:
This software is written using the language "Hollywood" and uses the RapaGUI plugin. Installation of the RapaGUI plug in is mandatory to run this program. If you haven't installed this plug in already http://www.hollywood-mal.com/download/RapaGUI_Amiga.lha (for Amiga family) or http://www.hollywood-mal.com/download/RapaGUI_Win32.zip (Windows) and install it to your system. Other requirements are low: A screen resolution of at least 800x600 and a 32 bit processor plus a few MB available RAM.
