WinUAE v4.2.0 Beta Beta 4
Messaggioda AMIGASYSTEM » sab mar 02, 2019 10:08 pm
WinUAE 4.2.0 Beta 4 32 Bit: Download
WinUAE 4.2.0 Beta 4 64 Bit: Download
WinUAE 4.2.0 Beta 4: Nuova beta dell'emulatore più famoso per AMiGA, tra le novità una maggiore velocità.
Va ricordato che utilizzare l'ultima versione garantisce migliore compatibilità e la giusta potenza per ogni modello Amiga emulato. Usare vecchie versioni apparentemente più compatibili comportano velocità dove non serve e lentezza dove invece serve più velocità, anche la compatibilità va a perdersi utilizzando vecchie versioni, rispetto alle vechie versioni sono stati corretti migliaia di bug e innumerevoli anomalie e incompatibilità.
Le novità di questo update:
- Enabled color burst bit emulation always made display grayscale except if BPLCON0 was not modified during frame.
- Adjusted color burst emulation: if genlock is connected, color burst state is ignored. Grayscale due disabled colorburst when using genlock is impossible because it is connected to RGB port and color burst only affects composite video out.
- 410b7 sprite FMODE=3 to lower FMODE value mid scan line update affected (parts of sprite disappeared) non-FMODE=3 sprites in certain situations.
- UAE RDB hardfile mounting didn't stop partition enumeration if number of partitions in single HDF exceeded max amount UAE HDF/directory partitions.
- Magic mouse change (b2) reverted and correctly fixed now. Only reactive WinUAE when mouse is moved back over WinUAE window with focus still active.
- 68020/030 cycle-exact: CPU to AGA chipset bus write waited full chipset cycle to finish which is not correct. Written data is latched by chipset buffers allowing CPU to continue executing after 68020/030 CPU memory cycle finishes (which is shorter than chipset cycle). This update slightly increases write speed to chipram/custom registers. (and probably fixes some demos and breaks others as usual)
- D3D11 shader viewport coordinate fixes. (pre and post shaders)
- Added Prelude (Zorro II) and Prelude 1200 (clock port) sound card emulation. (Hardware info from Oliver Gantert)
Prelude emulation notes:
- Prelude is similar to Toccata. PIO data transfers, FIFO memory and CS4231a audio codec chip. Toccata uses AD1848, CS4231a is fully compatible with AD1848 and also has some extra features.
- Prelude 1200 driver only initializes if card.resource exists: HW config must be A1200 with A1200 KS ROM. (=hardware with clock port)
- There may be something wrong with AHI (version specific?), test sound plays at 8000Hz instead of 44100Hz.
- I am not sure which AHI version is required. First I tried some 5.x AHI and device was detected but test button did nothing (also no HW accesses whatsoever when button was pressed). Replaced with 6.0 and test sound worked.
-> don't immediately assume problem is in emulation!
Immagine - AfA One - AfA One PPC - AROS One x86 - AROS One 68K - WinUAE OS 4.1 -
Re: WinUAE v4.2.0 Beta Beta 4
Messaggioda Seiya » sab mar 02, 2019 11:35 pm
chissà perchè non vuole emulare la Cybervision64/3D che sono schede grafiche esclusive su Amiga. Il discorso del Virge che non lo usa nessuno è una scusa vecchia come l'universo. Sono schede classiche e questa mancanza rende WinUAE monco di due schede grafiche storiche.
Messaggioda Frenika 2 » lun mar 04, 2019 11:06 am
Seiya ha scritto:chissà perchè non vuole emulare la Cybervision64/3D che sono schede grafiche esclusive su Amiga. Il discorso del Virge che non lo usa nessuno è una scusa vecchia come l'universo. Sono schede classiche e questa mancanza rende WinUAE monco di due schede grafiche storiche.
Perché continuano a chiederle con insistenza. è un tipo strano.
Frenika 2
Amico
Messaggioda AMIGASYSTEM » lun mar 04, 2019 11:52 am
Non è un tipo strano Toni, è una persona molto preparata forse il Numero 1 sulla conoscenza Amiga e non solo visto che lo fa girare su PC. Seiya ha già avuto una risposta da Toni per questa richiesta, leggi QUI, anche se credo che prima o poi emularà anche la Cybervision64/3D, stessa cosa accadde per OS4 dove lui era contrario a emularlo ed oggi invece abbiamo anche quella.
Messaggioda Frenika 2 » lun mar 04, 2019 5:50 pm
Conoscevo già la risposta, la mia era una battuta.
Magari non sapeva di nulla.
Frenika 2
Amico
