Wet v6.6/6.7 OS3/OS4
Messaggioda AMIGASYSTEM » ven feb 08, 2019 1:36 pm
Wet: App meteo sul Workbench per OS3 e OS4
NB: Questo update aggiornerà a 6.6 la versione OS3 e 6.7 quella di OS4
This program retrieves local meterological data from the Internet, and saves it in (regulary updating) env-vars to allow you to display it in the WB titlebar, as an icon on Workbench, AmiDock or in the GUI. It can show a forecast for up to 24 hours ahead (where available), and is fully localisable.
This is a patch file to update to v6.7. You will need v6.1 or higher
installed first.
Wet v6.6/6.7: Download
Updated translations for:
- Basque
- Czech
- German
- Italian
- Polish (OS3 only)
- Spanish
- Turkish
Changed in this release:
6.7 (07.02.2019) OS4 ONLY
The data is now hosted at an HTTPS location and the program has been
Currently
6.6 (28.10.2018)
METAR code GS has been reclassified as "snow pellets" in the USA.
(was previously "small hail/snow pellets" but we only printed
"small hail" for this code) (this is a catalog update only)
(was supposed to release this on 13th September but I forgot!)
