RedPill v0.6.8
RedPill v0.6.8
Messaggioda AMIGASYSTEM » dom dic 02, 2018 2:05 am
RedPill: Uno strumento che consente di creare molti giochi per Amiga senza conoscenze di programmazione, RedPill è un'applicazione professionale facile da usare e allo stesso tempo permette di fare cose complesse con poche funzioni consentendo la creazione di giochi 2D con il classico stile Amiga, piccolo Tutorial Video
RedPill Webpage
RedPill v0.6.8: Download
Novità di questa versione:
-About and Settings sections have been merged in Settings.
-New Project now asks for confirmation.
-Only used gameobjects are saved, decreasing the size of the .pill file significantly.
-New cursor design
-Added a Clear Map button to clear the current map.
-In Level menu, you can specify the exits of the map in the 4 directions. The exits point to other level numbers, use -1 to assign no exit.
-Added action trigger Keep on Map to avoid an object getting out of map dimensions.
-Added action trigger Check Exits to check current object against map dimensions and it will trigger the change of level.
-Added 4 action triggers Set Exit <X> to modify the level exits.
-Added Impact action trigger to transmit motion impact from one object to the impacted one.
-Flash Object trigger no longer makes the object blink, it stays in the same color for the length of the flash.
-Change between levels has been modified to avoid a frame with incorrect render at the start of the change.
-Added checks to avoid a crash when the system cannot find the tileset file in the project.
Visitano il forum: Majestic-12 [Bot] e 43 ospiti
