Workbench Explorer v2.1 OS4
Messaggioda AMIGASYSTEM » gio set 13, 2018 11:46 pm
Workbench Explorer (WEx) è un moderno gestore di file con diverse nuove funzioni tutte da scoprire
Workbench Explorer v2.1: Download
Workbench Explorer (WEx) is a modern file browser loaded with the features you are used to, but also with several new functions/features no other file browser has.
I hate writing manuals, but do read the included the AmigaGuide and Office compatible doc file.
In Preferences->Installed tab there is a list of items that will add extra functionality if they are installed.
Turn on Preview pane to:
* View images
* Read text files
* View GIF anims
* Play MP3s
The purpose of Commodity Mode is to have WEx started at boot up (WBStartup) and will be running in the background. Then using the hotkey (default: LAmiga + E) it will open. Closing the window will ony hide the interface.
