WinUAE 4.1.0 Beta 4
WinUAE 4.1.0 Beta 4
Messaggioda AMIGASYSTEM » dom set 09, 2018 7:25 pm
WinUAE: Nuova beta che corregge ed aggiunge nuove funzioni al miglio emulatore Amiga
Novità Beta 4
- Horizontal mid-screen resolution changes (Disposable Hero title screen, Runaway / AD 2000 second disk first part) broke when subpixel support was added.
- Filter GUI masks/overlay selection menu was unnecessarily cleared and filled each time option was changed.
- 53C80 SCSI bus reset didn't disconnect active SCSI devices.
- 53C400 compatibility fixes (RT1000B)
- Added x86 bridgeboard compatible 8-bit SCSI adapter: Rancho Technology RT1000B.
- Fixed stuck keys/mouse not getting captured if ALT-TAB was pressed and while keeping ALT pressed, TAB was used to select WinUAE window again.
- Added quick search text box to Configurations panel. Searches from config file name, description and new tags config entry (config_tags=<tag1,tag2,..>).
- Added quick directory select to Configurations panel. Filters by directory or category. Category is new config entry (config_category=<category name>).
- Moved Link and autoload options under Advanced information. Added Category and Tags fields.
- Ignore Huawei mobile USB sticks that have fake CD mode, they hang if SPTI SCSI read is attempted.
WinUAE 4.1.0 Beta 4 : Download
WinUAE 4.1.0 Beta 4 (64Bit): Download
Visitano il forum: Nessuno e 31 ospiti
