WinUAE 4.0.1 x86 Bridgeboard Update
Messaggioda AMIGASYSTEM » gio ago 09, 2018 11:38 pm
WinUAE 4.0.1 x86 Bridgeboard update: Con questa nuova release grazie al "PCem Core" molto probabilmente si potrà emulare anche un 486 e gestire una Sound Blaster, allego un mio vecchio tutorial sull'emulazione x86 Bridgeboard A2386SX su WinUAE.
Tutorial: WinUAE: x86 Bridgeboard A2386SX
WinUAE 4.0.1 x86 Bridgeboard update: Download
Bridgeboard emulation now uses following PCem "parts":
- CPU
- Interrupt controller (PIC)
- Timer (PIT)
- DMA controller
- NVRAM (286+)
- Memory and IO mapping.
- PC Speaker (enable option in Bridgeboard expansion GUI)
- Sound Blaster (Multiple variants, Expansion GUI, see below)
Previously emulated hardware still supported:
- VGA.
- XTIDE.
- NE2000.
- Floppy controller. (may be replaced with PCem version later)
Notes:
- FPU is not available (it looks like PCem only supports it if 486+?)
- A2386SX probably still isn't any more compatible because VLSI chipset used is not yet emulated in PCem.
- Speed is slower than previously, most likely because previously it was far too fast. Speed adjustment will be added later.
- Sound Blaster is totally untested, PC Speaker confirmed to make sound.. Because all supported SB models are in single expansion panel hardware option, not all options are specific to selected SB model. You MUST know how to configure SB. Do not expect GUI defaults are valid!
- Because IO/memory mapping is more flexible in PCem, bridgeboard IO mapping is now fully dynamic which may fix some previously weirdly working PCPrefs bridgeboard configurations.
- Do not skip directly to SB and assume everything else still works! Make sure previously installed disks/HDs still work. PC Speaker must be tested first! It must be done step by step!
- Do not click Restart or load new config on the fly! Always quit and restart whole emulator!
- TODO: A2386SX shadow/ems mapping register support should be relatively easy to implement with PCem RAM mapping system.
- A2386SX shadow/ems mapping implemented (mostly)
- SB16 MPU-401 interface added from PCem (maps to IO Ports panel selected MIDI out port)
- RTC date sync
- CPU panel speed adjustment works now (except Max which probably can't work with PCem, it would break CPU/timer sync)
When using VGA board, remember to configure it to use Monitor 2 (RTG panel). No need for annoying END+F9 swapping.
WARNING: This is not PC/DOS/SB (configuration) help thread! You must know how to configure IO ports, IRQ etc!
Re: WinUAE 4.0.1 x86 Bridgeboard Update
Messaggioda AMIGASYSTEM » sab ago 11, 2018 12:57 pm
Fatti i primi test con la nuova versione di WinUAE "PCem Core", adesso è possibile utilizzate il "PC Speaker" e ascoltare la musica e i suoni sulla x86 Bridgeboard, in allegato un piccolo file di 1,2 MB che mostra il test audio/video
Messaggioda AMIGASYSTEM » dom ago 12, 2018 1:05 am
Avete mai visto girare velocemente e a tutto schermo DOOM o DOOM 2 su un AMiGA 500 :ride: , bene, con A500 + x86 Bridgeboard è ora possibile fare tutto questo, naturalmente anche tutti gli altri modelli AMiGA emulati possono fare la stessa cosa e molto altro ancora :happyboing:
Messaggioda AMIGASYSTEM » dom ago 12, 2018 9:43 am
Per chi avesse qualche dubbio ecco fatto un bel video che mostra l'esecuzione di DOOM1 e Doom2 con AMiGA 500 x86 Bridgeboard (PCem Core) A2386SX-XTIDE Workbench 1.3
WinUAE: AMiGA x86 Bridgeboard A2386SX-XTIDE OS1.3 Doom 1 and Doom 2
Messaggioda cip060 » dom ago 12, 2018 11:20 am
Dal video non mi pare che giri cosi' velocemente
Gira come se girasse veramente su un 386 a10 MHZ :annu: :annu:
Messaggioda AMIGASYSTEM » dom ago 12, 2018 11:57 am
Si è vero ma è così che deve andare, calcola comunque che sta girando lato AMiGA su un A500/1MB Chip/1MB Fast/ 7MHZ quando su OS Amiga giocare a schermo intero occorrerebbe invece uno 060 e tanta RAM.
Siamo ancora agli inizi, fra un po' si potrà eseguire anche un 486 e installare senza problemi Win95, già lo sto installando adesso su un x86 Bridgeboard A2386SX.
Messaggioda AMIGASYSTEM » gio ago 16, 2018 12:02 am
Lanciare Win95 in SVGA da un A500 ... nessun problema, disponibile audio e mouse di sistema :ride:
Messaggioda AMIGASYSTEM » dom ago 19, 2018 7:19 pm
Ancora un test con AMIGA 500/OS 1.3 che emula Windows 95 ed esegue il gioco Aladdin, questa volta è possibile vedere il mio test attraverso il video in allegato, la lentezza di Win95 non è dovuta all'emulazione ma al programma di registrazione video che rallenta il processo di emulazione.
WinUAE x86 Bridgeboard PCem: Amiga OS 1.3 esegue Windows 95
