Uae4All2 Vita Mod v1.69
Messaggioda AMIGASYSTEM » mer ago 08, 2018 8:19 am
Uae4All2 Vita Mod: Nuova versione del famoso Emulatore Amiga per Playstation Vita, tutte le altre info le trovate nel link postato del download:
Uae4All2 Vita Mod: Download
Uae4All2 Vita Mod: Tutorial Video
Vita-exclusive Features
Full speed emulation of most Amiga games with zero frameskip
Large, complete virtual keyboard with adjustable position and adjustable transparency
Three fully mappable custom control sets: map Vita buttons to any Amiga joystick or key input, three custom control sets supported
Multiple hard-file support: up to 4 hdf files (size <2GB each) can be mounted simultaneously
Multiple controller support on Vita TV: up to four paired controllers can be fully mapped
Analog mouse control: control the mouse using the analog stick with adjustable sensitivity
Shader support: default "sharp_bilinear_simple" uses integer pre-scale for sharp, undistorted pixels with minimum blur, even if game is zoomed to fill the full Vita screen
Custom autofire: any mapped Vita button can have autofire with adjustable rate
Savestate with hard-file support: state can be saved even when hard-files are used
Additional emulator settings: sprite-sprite collisions can be enabled, blitter settings can be changed
Adjustable stereo separation
A button can be mapped to "slow mouse" in custom controls. When custom controls are on and that button is held down, the mouse pointer speed is greatly reduced. This is useful for precisely positioning the cursor.
Bluetooth keyboard and mouse support
Sticky virtual keyboard modifiers: allows keyboard combos like CTRL-C to be entered easily
Touchpad style pointer controls using the front touch panel and (optional) the rear touch panel
Supports loading files from ux0: or uma0: partition
Parallel port joystick adapter support for multiplayer games with up to 4 joysticks.
Visitano il forum: Nessuno e 46 ospiti
