Icon.library v46.4.490
Messaggioda AMIGASYSTEM » gio ago 02, 2018 11:41 am
Icon.library: Nuova uscita della famosa libreria per gestire qualsiasi icona del mondo AMiGA e non solo, tutte le informazioni sulle ultime release le trovate nel link del download.
A new test candidate: TC020, which supports TrueColor for the OS4 ARGB icons. It can display in TrueColor with alpha channel and save in OS4 format now, but PNG is not supported yet. PNG may come later, since it's a bit more difficult to integrate. The other versions like 68020 have no new features. The icon scaling is not supported in TrueColor quality, because that would need a zlib compression routine.
Due to a bug in AfA_OS the new created OS4 icons may not be displayed by AfA's icon_lib.exe. AfA tries to read the ARGB image size from the DiskObject Gadget structure instead of taking the width-1 and height-1 values from the FORM chunk. AfA also makes ARGB icons unreadable for OS4 when the Gadget size is different to the ARGB image size. I don't want to make a work around for AfA in this case, because that would need a wrong gadget size.
Icon.library v46.4.490: Download (recensione ufficiale autore)
Per facilitare l'utilizzo della icon.library sotto OS 3.0 / 3.1, nello stesso link del download sono disponibili due immagini ADF bootable (IconDemoADF) che permettono di capire il funzionamento della libreria.
Re: Icon.library v46.4.490
Messaggioda AMIGASYSTEM » gio ago 02, 2018 3:17 pm
Amiga ha scritto:Due to a bug in AfA_OS the new created OS4 icons may not be displayed by AfA's icon_lib.exe. AfA tries to read the ARGB image size from the DiskObject Gadget structure instead of taking the width-1 and height-1 values from the FORM chunk. AfA also makes ARGB icons unreadable for OS4 when the Gadget size is different to the ARGB image size. I don't want to make a work around for AfA in this case, because that would need a wrong gadget size.
Riguardo questa citazione non avendo avuto alcun problema sul mio AFA-OS ho fatto una segnalazione al bravo Peter autore della Icon.library, QUI e possibile leggere la discussione.
Ricordo per chi non lo sapesse che AFA-OS non fa uso della "Icon.library" ma "utilizza la sua icon_lib.exe", un sistema basato AFA-OS utilizza la Icon.library standard solo se si decide di avviare AFA-OS senza le sue librerie tramite il tasto del Mouse (disattivazione temporanea di AFA-OS).
Messaggioda DanyPPC » gio ago 02, 2018 4:56 pm
Ne esce un update al giorno !
A1200 OS3.0 2MB
A600 OS2.0 1MB/Gotek Drive
DanyPPC
Messaggioda AMIGASYSTEM » gio ago 02, 2018 8:10 pm
DanyPPC ha scritto:Ne esce un update al giorno !
Quasi, tutto dipende dai bisogni e dalle segnalazioni degli utenti (come la mia di oggi) e dall'emancipazione della libreria, il pacchetto sempre più ricco di utility consente di avere notevoli miglioramenti anche sui vetusti OS Amiga 3.0/3.1 dove è ora possibile avere qualsiasi tipo icona.
Messaggioda AMIGASYSTEM » gio ago 02, 2018 11:40 pm
Come dimostrato dai miei test AFA-OS non ha nessun problema sulle icone trattate con Strumenti come CopyIcon, RAWBInfo, Drag & Drop e vari slavataggi da "Icon Information" fatti su sistemi 3.5/3.9 almeno su icone native OS 4.1 o immagini PNG. Dopo accurati test anche da parte dell'autore abbiamo accurato che il problema si presenta solo sulle icone native OS 4.0, che restano ben visibili dopo la manipolazione su 3.5/3.9 ma scompaiono sui sistemi basati AFA-OS, allego le motivazioni tecniche date dallo sviluppatore:
"Maybe the OS 4.1 icons all have correct 4-color planar images with the same size as the ARGB images. Then my library won't replace the planar images by default and AfA has no problems. But many old OS 4.0 icons still have these stupid 256 color pklanar images include which looks terrible wrong without a palette. (I don't have OS 4.1)"
Naturalmente chi usa AFA-OS non avrà alcun bisogno di manipolare le icone prima su sistemi 3.5/3.9 perchè potrà farlo comodamente su AFA-OS dove peraltro ci sono strumenti più aggiornati e dove la qualità delle icone è al top.
