WinUAE 4.0.1 Beta 3/4
Messaggioda Amiga » mer lug 11, 2018 3:09 pm
WinUAE: Ancora un doppia beta che fixa e aggiunge nuove funzioni all'emulatore
Novità beta 3: (Possibly final beta, I wasn't supposed to do 4.0.1 vsync updates but below updates should have been in 4.0.0..)
- If CD audio playing from real/virtual CD (not directly mounted image) was restarted because of config change, playback always started from beginning (or possibly failed to restart).
- 68060 FPU disable behavior change (68060 accelerator boards have "$f0" ROM to disable FPU because exec does not understand 68060 FPU and will crash if enabled), FPU is not anymore automatically disabled at hard reset if any emulated accelerator board is configured (matches now real world), if no accelerator board: if UAE boot ROM is at $f00000 ("old" mode), it disables FPU (just like real accelerator board do), if UAE Boot ROM is any other address: ("new" mode), m68k RESET instruction will disable FPU. Previously 68060 config got stuck in reboot loop because of not-disabled FPU if system was software reset.
- D3D9/11 vsync modes (lagless and standard) will now support 100/120Hz with optional black frame insertion.
- Always check interrupts immediately after MOVE to SR instruction (except if JIT enabled). Previously it was delayed until following instruction if fast 68020+ mode.
- Above FACOS JIT fix.
Novità beta 4:
- Floppy, CD, Tape, HDF geometry, HDF filesystem, disk swapper, RTC and flash rom file paths also support b1 resolve environmental variables update. (b1 update had issues requiring partial rewrite so it was good idea to update all other paths too. Excluding special paths like ROM paths.)
- Previously only some SCSI controllers flashed CD led when emulating CD drive.
Short description about path handling change: Previously any path was always converted to either full absolute or relative path with possible environmental variables resolved when config was loaded or path was typed/selected from dialog. When config was saved, old path (possibly containing environmental variables) was lost. Now paths are loaded unmodified from config file and only converted when needed. "Normal" path strings (no environmental variables) are still automatically converted to absolute/relative when saving config.
WinUAE 4.0.1 Beta 4 : Download
WinUAE 4.0.1 Beta 4 (64Bit): Download
Amiga 4000/060 Ram 64 Mega Kick 3.1 MK II
Amiga
