MorphOS v3.11
Le nostre news.
MorphOS v3.11
Messaggioda Amiga » lun lug 09, 2018 9:08 am
MorphOS nuovo aggiornamento, queste alcune delle novità:
Emulation
- Fixed CAS/CAS2 instruction emulation
Hyperbootloader
- Convert 'ISO9660' into 'CD0' when creating the command line for booting MorphOS. Fixes a delay when booting from CD
P50x0_eth New
- A resource used for handling access to resources related to P50x0 Ethernet.
Quark
- Map the second Frame Manager on P5040 machines
Powerbook
- Fixed PowerBook5,6 and 5,7 fan control
- Fixed a memory leak on older PowerBooks and iBooks that would leak a little memory every second, also caused a performance hit over time
- Fixed a rare memory leak in battery handler
Ambient
- Fixes in keyboard handling in listers
- Fixed double-clicking on Lha archives
- The LOADURI ARexx command now uses default view and default view mode if one or both of them are omitted
- Added a "Open Parent" to the context menu of a panel button to open a lister
- Inline edit, pressing space delete a sign/entry or jumps to the next entry
- 'Create Archive' fixed to add multiple files to a single Lha archive
MorphOS v3.10: Release Notes
MorphOS v3.11: installation
MorphOS v3.11: Download
Amiga 4000/060 Ram 64 Mega Kick 3.1 MK II
Amiga
