RNOComics v1.2 OS4/MOS
Messaggioda AMIGASYSTEM » ven mag 11, 2018 8:22 pm
RNOComics è un visualizzatore di Fumetti in grado di visualizzare "file archivio" o file da directory mostrando le immagini in una particolare GUI progettata appositamente per la lettura dei Fumetti, tra i formati supportati troviamo: CBR, CBZ, CBT, e qualsiasi altro formato di archiviazione supportato da XAD.
RNOComics v1.2 OS4: Download
RNOComics v1.2 MOS: Download
Features
- Supports CBR, CBZ, CBT, e qualsiasi altro formato di archiviazione XAD supports
- Supports online Issuu publications
- Unarchives images on the fly, no HD space or memory wasted
- Read-ahead cache for the next page
- Can continue to the next archive file in a directory with a single command
- Can open directories with unarchived images and work as an image viewer
- MUI GUI with controls as buttons, menu items, and keyboard shortcuts
- Three different layout options: fit width, single page, and double page
- Fullscreen mode option
- Zoom option displays comic's pages at their intended maximum resolution
- Rotate options for portrait mode making viewing/reading easier
- History window with front page thumbnails and page memory
- Backwards reading options for manga comics
- Can save and export images
- Can create thumbnail PNG icons for archives
- Gamma correction options
- Drag & drop loading
- ARexx support
Installation
- Copy the whole directory anywhere you want
- If you're using an OS4 beta or the program fails to start, copy the
muiroyale.hwp file to LIBS:Hollywood/
- reqtools.library is required for the background color selector:
http://os4depot.net/share/library/misc/reqtools.lha
Controls
Right/Command+N/N . - Loads the next page
Left/Command+P/P . . - Loads the previous page
Home/Command+T/T . . - Loads the first page
End/Command+L/L . . - Loads the last page
Space/Mouse wheel . - Scrolls the page or loads the next page depending
on the layout selected
Up/Down . . . . . . - Scrolls the page
PageUp/PageDown . . - Scrolls the page in larger steps
Held LMB/MMB . . . . - Zooms the image to its original size
Rotate mouse wheel . - Over page gadget for precise page selection control
and then click 'Go' to load the specific page
Command+Z/Z . . . . - Toggles the zoom mode on/off
Command+O/O . . . . - Opens a new comic book archive or a picture file
Command+X/X . . . . - Opens the next comic book archive in the current dir
Command+I/I . . . . - Opens a directory and loads unarchived images from it
Command+A . . . . . - Saves the original image
Command+G . . . . . - Saves the displayed page as a PNG image
Command+F/F . . . . - Toggles the fullscreen mode On/Off
Double-click . . . . - Toggles the fullscreen mode On/Off
Esc . . . . . . . . - Exits from fullscreen mode
Command+H/H . . . . - Opens or closes the history window
Command+W/W . . . . - Changes to the "fit width" layout
Command+S/S . . . . - Changes to the "single page" layout
Command+D/D . . . . - Changes to the "double page" layout
Command+E/E . . . . - Rotates the image 90 degrees to the left
Command+R/R . . . . - Rotates the image 90 degrees to the right
Command+"+"/+ . . . - Increases the gamma correction value
Command+"-"/- . . . - Decreases the gamma correction value
Command+0/0 . . . . - Resets the gamma correction value
Command+Q . . . . . - Quits the program
Re: RNOComics v1.2 OS4/MOS
Messaggioda Kyle » sab mag 12, 2018 8:23 am
Interessante :felice:
Però non saprei dove scaricare dei fumetti :riflette:
