PFS3 All-In-One 3.0 Final
Messaggioda AMIGASYSTEM » sab mar 10, 2018 10:22 am
PFS3 All-In-One è un Port della versione open source di PFS3 (Professional File System III) sviluppata da Toni Wilen, trattasi di un Filesystem AMiGA molto potente che supporta al 100% tutte le CPU e gli OS Amiga da 1.x a 3.x., il pacchetto include anche vari Tools per la gestione degli Hardisk.
Queste le novità della versione 3.0
- Bug fixes, including finally fixed nasty bug causing Wrong Index Block ID (and others) if partition was >=5G and lots of small files were created very quickly, for example unpacking archive with thousands of small files. This bug has most likely existed since PFS3 introduced >=5G partition support.
- Compiled with m68k optimized GCC 6 (https://github.com/bebbo/amigaos-cross-toolchain), 16k smaller than previous pfs3aio.
- Some HD controllers modify MaxTransfer after filesystem has been initialized, which was ignored by previous versions.
- Automatic max transfer limit is only enabled if scsi.device version is v36 or newer and older than v50.
- Limit Direct SCSI mode max transfer size to 65535 blocks (~32MB).
- Automatically attempt to increase number of buffers if all buffers are in use and more buffers are required.
- Added support for new OS 3.1.4 filesystem mount flags. (SCSIDIRECT, SUPERFLOPPY and DISABLENSD).
- Shows more detailed information in error requesters (access mode, start block, end block, SCSI details if SCSI Direct)
- Includes unsupported and experimental >104G partition support. Shows warning if enabled during formatting.
- ACTION_DIE (unmount) stability fix.
- Filename changed from pfs3_aio-handler to pfs3aio.
PFS3 All-In-One 3.0 Final: Downlaod
Visitano il forum: Nessuno e 126 ospiti
