implementazione fuse filesystem
Messaggioda sabbate » gio lug 16, 2015 6:52 pm
Fredrik Wikstrom has notified Power2People that he considers his work on the "FUSE Filesystems" bounty project to be finished.
You can access a test version via this web address:
https://dl.dropboxusercontent.com/u/26 ... aros-filesysbox-ntfs3g.7z
The installation procedure is as follows:
copy filesysbox/filesysbox.library sys:libs
copy ntfs-3g/ntfs3g-handler sys:l
The archive includes an example mountlist file in ntfs-3g called "NTFS0".
For a list of the requirements that must be met by software, please visit:
http://power2people.org/projects/fuse/
Power2People relies on the AROS community to test if a bounty project has been successfully completed. So, please post a comment if you have encountered any problems or know other reasons why the bounty project cannot be considered to be completed just yet.
Thank you.
sabbate
Torna a AROS e compatibili
